8 Pole Heli Motor in an E Revo?
sikeston34m
sikeston34m's Avatar
8 Pole Heli Motor in an E Revo? - 08.11.2010, 10:19 PM
Hi Guys,
I've always been one to experiment with different motors. This has gave birth to a pretty good motor collection. LOL
Not afraid to think out of the box, I'll try almost anything that might work.
This time, something good was discovered.
Outrunners make tons of torque and I've always been fascinated by them.
Recently a Scorpion 4020-1390kv 8 pole outrunner was acquired.
The shaft had to be cut down since it was way too long to fit. Then a small flat was ground to seat the set screw.
The first setup that was attempted was for 4S, and geared 24/40 using Mod 1 gears. 40mph or so.
The motor was running warmer than I like, and the ESC was getting warm too. 4S power was supplied by a PAIR of 20C 4000mah 4S packs. The packs didn't break a sweat, but everything else was. The setup ran very good though. The run was stopped when things began to heat up.
Time to rethink this.
The gearing was changed to 20/52 using Mod 1 gears. Again, geared for about 40mph on 6S.
6S power was supplied by a pair of Apogee 20C 3800mah packs in Series.
This setup is the sweet spot for this motor.
Rolling backflips and wheelies. Dirt Slinging fun.
I ran the setup until it just bumped the 3.2 volt LVC setpoint in the MMM.
Motor temps were pretty good throughout the run considering the 95 degree temps outside. The fan on the endbell of the motor moves a fair amount of air. Motor temps didn't surpass 130 degrees or so.
ESC temps were better, and tolerable although the fan ran most of the run.
The Packs on the other hand, I feel, took a beating. I don't think they are quite up to the chore. They came out pretty hot.
The ESC settings will improve this.
I changed the punch control from 50% to 100%. Start Power from High to Low.
Timing was set to low. Which is a no-no for outrunners, so I changed that to high. I will run it again with the new settings.
Anyway, here's what it looks like. Check it out and give me your thoughts.
