Got my 9918 today..
widemouthmaxx
widemouthmaxx's Avatar
Got my 9918 today.. - 03.19.2005, 03:38 AM
..anyway..it so pretty..all that nice heat shrink on there..which brings me to my question
How much of the wrapping do I need to cut before I can see the jumpers and what not.?
Also does anyone have any diagrams on the the batt wiring..I want to run 2 packs...sorry guys just so excited I need a bit of advice before I screw something up..thanks
Dafni
Dafni's Avatar
03.19.2005, 07:21 AM
The jumpies are on the side with the input cables!
You donīt have to cut much of the shrink, but every controller looks a bit different.
The black shrink is nice indeed, but when you run it, the shrinkwrap will shrink some more, so that the cut-out section for the heatsink will become bigger and rounder. My experience.
Just have a look at your batts and wire it so that all cells will be in series. I think thereīs a how-to thread here somewhere. But itīs really straight forward, just use common sense.
supermaxx4190
supermaxx4190's Avatar
03.19.2005, 11:46 AM
here ya go, man im getting good at my art skills:cool:
HotnCold
HotnCold's Avatar
03.19.2005, 12:10 PM
Picaso who - lol
Hows that "Hope and Change" working out for Ya???
widemouthmaxx
03.19.2005, 03:30 PM
Now that I see it, it make total sense..thanks..I cut away some of the shrink to get to the wrap..the black plug is right behind the power cap..have to lift it out a bid...hope I don't snap the solder.
Thanks for your help
Quebecois_Sti
03.19.2005, 06:32 PM
http://www.offshoreelectrics.com/bat...eries_or_p.htm
Series
Parallel
Olivier Mathieu
legomind@hotmail.com
widemouthmaxx
03.20.2005, 05:34 AM
Thank you fellow canadian...also I was reading the discription about the 9918..
"3Amp.BEC on/off Function"
on/off function? :C:
Also I'm only going to be using the single steering servo..do I stil need a UBEC? or is 3amps enough?
thanks once again
ex-novak dude
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
03.20.2005, 11:13 AM
You should be alright using the controllers BEC with a single servo. The UBEC will provide slightly higher voltage, but the controller's bec should hold up just fine with a single servo.
widemouthmaxx
03.21.2005, 06:48 AM
Thank you Mike for your professinal attitude...once you make a sale it doesn't end for you, which will make me spend more money.
Does higher voltage provide more power? What would you do?
Also, which aluminum wheel you have that is lighter and will work with 40 seris road tires?
Thanks
RC-Monster Mike
Site Owner
03.21.2005, 09:54 AM
Higher voltage will potentially provide more power to your truck, but not your servos. If you have decent steering servo, the controller bec will give you plenty of power. For Aluminum 40 series wheels, there aren't a lot of options. I don't stock any, but can get some from my distributor. The ones there are quite pricey, though($200+ per set)!
JOHNNYMAXXIMA
RC-Monster Dual Brushless!
JOHNNYMAXXIMA's Avatar
03.21.2005, 05:18 PM
Am I supposed to solder my UBEC to the deans plugs of the esc? (red to red and black to black obviously)?
As for the wire that supermaxx4190 has marked "Jumper" can I use the excess wire that I cut off of the ESCs (the 3 wires that lead to motors) for this "Jumper"
widemouthmaxx
03.21.2005, 08:05 PM
200.00 bucks??? damn...I might as well ordere some proline shocks from you. BTW..I got my 9L today..thank you very much Mike.
A friend is going to help me wire everything up...
as for the motor wires and the esc motor wires..I can connect these in any order?
then adjust forward and reverse later via programing..right?
Also the UBEC that I got today (a local brand that is hand made)..can I put it in line with the reciever wires then plug into the reciever batt channel?
then what do I do with the black jumper?
In or out?
I did the read the sticky a thousand times regarding set up but I just want to be sure..thanks
RC-Monster Mike
Site Owner
03.21.2005, 08:12 PM
You can connect the motor wires to the controller wires (three blue wires) in any order. Changing the rotation direction is quite simple. When you use the external bec, you should remove the black jumper. To wire the bec, solder the red wire from the bec to the deans on the controller (same place you solder the red controller wire), and the black to the other deans (again, the same place you soldered the black controller wire). Then it should plug into the receiver as you mentioned. make sure you have nice solder joints and you should be in good shape. Let me know if you need any more help.
Mike
RC-Monster Mike
Site Owner
03.22.2005, 10:29 AM
You can use any wire you want as the jumper. Just make sure it is a nice guage wire (12 or 13 guage is fine).
