unsolder battery leads from MMM?
candy76man
unsolder battery leads from MMM? - 02.15.2012, 05:53 PM
Is there some trick to getting the original battery leads unsoldered from the MMM pcb? I am using a 100watt soldering gun and it's like the solder doesn't want to melt all the way through so I can remove the wire. The heatsink on the MMM seems to be sucking up all the heat from the soldering iron before the solder can liquify completely but it has to be possible right?
