Total Capacitance?
Bazzokajoe
Total Capacitance? - 02.27.2012, 03:19 PM
Hey,
Anyone know what the capacitance ratings on the MMMXLv2 are?
And what about the Ratings on the Castle Cap pack?
Trying to work out what resistor i would need for no spark connection...
Thanks guys!
freddy
02.27.2012, 07:33 PM
You dont need an resistor, the spark especially with 6s is not that bad.
on 8s your getting an smal "bang" but it will take a long time before it will ruin any connectors.
fastbaja5b
fastbaja5b's Avatar
02.27.2012, 08:10 PM
Maybe we're just scaredy cats!
From what I could tell the cap pack was 880uf total, the esc had 2 * 680uf that I could see.
I'd love a clear answer on what resistor to use as well. I have a 1 ohm 10 watt in there now but it looks friggin huge. I've seen one post where Patrick has said 1 ohm 5 watt, but that was for 6s? Even that resistor is fairly big, it does your head in doesn't it?
Say Less, Do More.
Bazzokajoe
02.28.2012, 08:16 AM
i run my 5b conversion around a lot of petrol bajas, with all the flammable liquids around i would rather not have the 8s crack and spark when starting up... just to be on the safe side... Plus the big scary spark makes me scared
FB5b, it certainty does do my head in... i was looking at 5ohm 10 watt and their monsters! i would love to have a definitive value,
so thats, 4x220uf on the cap pack, and 2x 680uf on the MMMXLv2?
according to brians calculator i will require a 45ohm, 20watt resistor to charge caps in half a second...
that seems CRAZY high?
Pdelcast
Pdelcast's Avatar
02.29.2012, 01:28 PM
You also might damage the ESC if the 45 ohm resistor is connected when the ESC beeps the motor...
Just use 1 ohm. It works fine.
Thanx!
Patrick del Castillo
President, Principle Engineer
freddy
02.28.2012, 07:54 PM
I dont think deans connector will last very long on 8s "sparks", but bullet will be ok, as it will only hit the edge and it have bigger contact area.
Guess its better to use resistor, but not really needed.
snellemin
2 KiloWatt RACER
snellemin's Avatar
02.28.2012, 03:15 PM
Man, you guys are a bunch of woosies.
I too use resistors, but only because I use 16-22S on my bike. I just use a pair of 1 Ohm/1W resistors in parallel. Small enough and no sparks. BTW, my bike has a like 19 caps.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
fastbaja5b
fastbaja5b's Avatar
02.29.2012, 09:09 PM
Ok simple Q time for people like Bazzokajoe and myself
If I run a MMMXL2 with a Cap Pack for a Baja and 2028 Castle Motor, on 6-8s Lipo we should use a no spark resistor of ________ ohm and _________ watt.
Don't need casual theorizing, just someone to fill in the blanks so we can go to radioshack and get the right resistor to hook in. Why is it so hard?
at present I am at 22 ohm, 1 watt.
Say Less, Do More.
02.29.2012, 10:03 PM
My calc simply displays the charge levels and power over time given the data entered. This is more for those who want more info. But, there is a section on that page that flat out tells you a general resistor to use for those who just want an easy blanket answer.
So, to reiterate; if you want those blanks filled, just follow Patrick's advice and use a 1 ohm, 5 watt resistor. Just be aware that as capacitance is increased, the charge time will increase (will be less than 1 sec unless capacitance is crazy high) and as voltage is increased, the resistor may get toasty so don't hold on to it.
fastbaja5b
fastbaja5b's Avatar
02.29.2012, 10:21 PM
...damn 5 watt resistors are friggin huge!
Say Less, Do More.
snellemin
2 KiloWatt RACER
snellemin's Avatar
02.29.2012, 10:31 PM
Man just use two 1W resistors in parallel. Small enough.
