Differential parts for FLM hybrids
extremexmods
Differential parts for FLM hybrids - 06.15.2014, 10:36 PM
Got a set of the FLM Hybrid bulks (requires 1/8th scale diffs) for my e-maxx just have a couple questions about the internals
http://www3.towerhobbies.com/cgi-bin...?&I=LXPLV9&P=7
would these work for the differentials? Does this also come with the center outdrive which goes between the differential and the center shafts to the transmission, or do I need to also purchase http://www3.towerhobbies.com/cgi-bin...?&I=LXDLD3&P=7 as well?
bearings: what bearings do I need to get? I see the differentials come with bearings, are they the proper size when used with the FLM hybrids or do I need to get different size bearings, if so which ones do I need? For the outdrives to the center shafts I believe the outdrives are not included so I probably need to get them too, therefore what bearings do I need?
Drive shafts: Maxx miv cvds all front rear and center. Do I need different output cups or will the current output cups work with the savage differential output shaft?
Shims: what size shims do I need? Do I need to shim inside the differential cup where the spyder gears are or just the left/right sides between the differential as well as outdrive in order to old the mesh with the ring gear?
