Power of Castle C 2200Kv motor on 6s
SpeedAssault
SpeedAssault's Avatar
Power of Castle C 2200Kv motor on 6s - 02.16.2017, 12:56 PM
Hi there,
I'm sure this info is out there somewhere, but have not found it yet. Please help direct me to the calculator to find:
What is the Torque and HP of the Castle Creations 2200Kv Brushless motor , 6s Lipo 25volts,
my custom 1/5 RevOsi:
Gear ratio 11:1
Pinion Mod 1 19t, or 24t
Spur 46t (Sliperential)
124x65mm wheels
11.3 lbs
Thank You
ruudxd
02.21.2017, 10:08 AM
I am not that good with numbers, but this site should get you on the way!
http://www.scriptasylum.com/rc_speed/top_speed.html
SpeedAssault
03.15.2017, 03:31 PM
Thank You RuuDxD
Even Castle did not know
Based on 120Amps:
2.84 ftlbs of Torque
Axle Torque 3.81
2.8 to 3.5HP
6S 25volts
Tire 4.8
Spur/Pinio Ratio 2.41:1
46Spur 19P
Theoretical Speed 78MPH
Calculated Motor Power 3024 watts (4.1HP)
At Under 11.5 lbs this would explain why the car from dead stop it Jumps straight up in the Air when Pull full throttle.
Kcaz25
Kcaz25's Avatar
03.16.2017, 07:38 PM
I have heard Patrick say that under hard acceleration the 2200kv MMM 6s combo could pull approaching 5 hp.
