Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
UE SuperShocks on stock suspension
Darren
UE SuperShocks on stock suspension - 07.15.2006, 11:58 AM
Will the SuperShocks work with the stock suspension? I know they are longer, so was curious.
I ordered some last night from mike.
Sneeck
RC-Monster Custom
Sneeck's Avatar
07.15.2006, 12:11 PM
Not without a minor modification. You need to put a small piece of fuel line or other spacer to limit the travel. Stock suspension can't handle such big shock's, had them myself on rpm arm's and without the spacer it sucked.
  Send a message via MSN to Sneeck
Darren
07.15.2006, 02:40 PM
To limit the downward travel right? If so, I have an idea...
On the stock lower arms the bottom shock mount screw holes are raised up. If you were to cut these off and have the shocks mount onto the arm like a truggy. There is just a hole cut out in the arm for them to fit in and a hole for the screw. It would mean that the shocks would have to be about 15mm longer or so, to fit perfectly. I'm not sure how long the UE ones are.
coolhandcountry
coolhandcountry's Avatar
07.15.2006, 02:43 PM
The ue I think are about 10 to 15mm longer than stock.
Peace!
Country
Help support the
Rc-Monster
Buy here
Darren
07.15.2006, 03:52 PM
This is what I was meaning, if you can see it properly, it was only a rough attempt, final version will be done better.
coolhandcountry
07.15.2006, 06:52 PM
I would try to go farther out towards the pillow ball.
Make it closer to the outer hole that you cut off.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
07.16.2006, 05:35 AM
can't you just flip the arms around?
Darren
07.16.2006, 05:36 AM
Sure will, that's just a silly little prototype to see if you all caught my drift.
Serum - Id still have to dremel material none the less.
Serum
Serum's Avatar
07.16.2006, 05:49 AM
Yeah, sounds fair to me, i guess it's the angle of the shock that gets in the way of the arm.
Darren
07.21.2006, 01:40 PM
Yay, I made it work!
Gonna post a little 'How To' on the UE Forum later.
Comments/flames/criticism etc... encouraged :) .
Sneeck
RC-Monster Custom
Sneeck's Avatar
07.21.2006, 01:51 PM
Look's like you need to get some more practice with the 'ol dremel lol.
j/k nice mod. Hope your arm's won't fold if you land a jump hard lol.
coolhandcountry
07.21.2006, 02:09 PM
Wouldn't it have been easier to get some front buggy shocks.
Peace!
Country
Help support the
Rc-Monster
Buy here
Darren
07.21.2006, 04:34 PM
Sneeck, I probably could, but it works.
CHC - I dunno, but I like the fact that they're UE. First UE part i've bought :) .
Mike.L
Mike.L's Avatar
07.24.2006, 11:12 AM
now that you made new holes darren, everything is on there but not every hole is in the exact position and now isn't the arm weakened by shaving more plastic off. I would understand if you used rpm.
  Send a message via MSN to Mike.L
Procharged5.0
Procharged5.0's Avatar
07.24.2006, 05:26 PM
Pick up a used set of UE Widemaxx arms for $100. It will look and work much better!
My .02
