What is a good charger? -
06.18.2006, 04:06 PM
Hey guys just wondering what I should pick up charger wise for the emoli 5s2p system I will be building. I currently have a GP triton that I think I could use if I built the packs like a 2s2p and a 3s2p and wired them in series. But I'd rather have a charger that I could charge all the cells at the same time. What do you guys recomend for a charger, don't want to go over $200.
06.18.2006, 06:08 PM
If you are willing to spend $200, the TP1010 is the best I think.
06.18.2006, 07:05 PM
Yeah, the TP-1010C for $200 is the way to go. You could charge that pack at 10 amps with the TP charger, which would give you a total charge time of about 50mins for a full charge.
Does your pack have taps? Taps are always a good idea so that you can balance a pack, and the Emoli cells aren't an exception. Although they may stay in balance well, they may not.
06.18.2006, 11:37 PM
Really whether I was going to install balancer taps was going to be dependant on the charger. If I go with a low C rated charger I wouldn't use taps as the emoli cells seem to balance themselves out well at low charge rates.
I like the TP-1010C, but its kinda high price for me ($260/$300 with balancer) for a charger that only charges lipo and lion. Since I race mod 10th scale and 10th scale rally as well I would like a charger that could do both lipo/lion and nicd/nimh. I sold my CE turbo 35 last year after I stopped racing but now that I'm getting back into it I'd like a charger with some of the nicer features like the turbo 35 that could also charge 5 cell lipo at a decent rate if one exists. I just havn't been in the market for a charger in a long time and don't really have too much time to do the research about what is around.
If I could find a competition level charger that could do both nicd/nimh and lipo/lion I would be willing to pay more than $200 as thats what I got for my used turbo 35 alone. I just don't know whats out there.
Thanks,
Pat
06.18.2006, 11:45 PM
The Schulze 330-D is an option. There about $170ish. The Hyperion EOS 7I would be another option for $120.
06.19.2006, 09:25 AM
I was going to also suggest the Hyperion EOS 7i. Compared to its little brother (EOS 5i/Multiplex LN-5014/etc.), it can charge faster and can do up to 25 NiMh cells.
06.19.2006, 03:34 PM
I use the 330-d and like it, but it's max current is only 5.5 amps. So you can only charge the 2p emolis at a bit less than 1C.
06.20.2006, 12:19 AM
Went with the Hyperion EOS 7i got it from Bishop power products for 145 shipped with the EOS balancer. Next question is does anyone have a diagram I could look at for wiring a pack up with balancing taps
06.20.2006, 01:15 AM
How did you/will you configure your packs?
06.20.2006, 07:48 AM
My pack will be a 5s2p pack most likely with 4 cells on one side of the buggy and 6 on the other, but permanently wired together in a 5s2p config. Still have to figure out what is balanced the best with everything on the buggy.
06.20.2006, 10:08 AM
How will you solder them together? I can do a quick drawing to show how the taps will go. If you're not sure yet, I can do a drawing demonstrating a way to solder them together.
06.20.2006, 01:04 PM
Not sure how I'm going to solder them up yet. I will be building them in sxs config using standard sub-c battery bars if that helps at all. Never built any packs with taps before so any help would be greatly appretiated.
06.20.2006, 03:36 PM
What's your battery space like? If you have a picture of your car and where that batteries will go, that would help.
Which taps (balancer) are you going to use?
06.22.2006, 02:27 AM
Can someone give a site for these chargers cause I will need one for some 6s packs.
06.22.2006, 09:28 AM
The Hyperion chargers can't do 6s Lipo. To get a 6s charger, you'll need to spend at least $120. The easier-to-get chargers include the TP-1010C and the Astroflight 109:
http://parts.rctoys.com/rc-toys-hobbies/Items/TP-1010C?
http://www2.towerhobbies.com/cgi-bin...&I=LXFWW2&P=ML
The 109 isn't the greatest charger. It isn't a CC/CV charger like normal Lipo chargers. You also can't do much with it in terms of buttons and changing settings.
| Thread Tools |
| Display Modes |
Rate This Thread |
Hybrid Mode
