wheelie bar problems and solution
capitol
wheelie bar problems and solution - 07.27.2006, 09:26 PM
I purchased this wheelie bar. After a while the WB started pushing up against the skid plate. It made far very long wheelies, but was ruining the tires and bending the bulkhead screws.
Next, I used a long screw rod with four tires and it really bent up everything.
Here is the threaded rod used with the four tires. Notice the 2 WB tires :005:
So here is my solution. I used shorter bolts and nuts to secure the WB to the bulks and went with two tires.
Notice I removed the bulkhead braces. Do you guys think this will cause a problem with my hybrid bulkheads?
