Esc
E-Maxx King
Esc - 11.20.2006, 01:26 AM
Would this ESC be relieable with a 9l or 9xl on 14 cells?
MetalMan
MetalMan's Avatar
11.20.2006, 01:41 AM
Did you mean to post a link?
E-Maxx King
11.20.2006, 04:37 PM
No, just aking If this setup is reliable!
neweuser
neweuser's Avatar
11.20.2006, 05:17 PM
I think his question is the MM esc, if so, yes, it'll do fine with a 9xl on 14 cells. I believe crazyjr is doing it now. Personally, I would not run a 9L in an Emaxx when the xl is a better option. IMO
E-Maxx King
11.20.2006, 05:52 PM
Sounds Good! Could you post a vid with this setup?
neweuser
neweuser's Avatar
11.20.2006, 05:58 PM
I don't own the actual system, and the guy that does may not have the capability to do so. But it works well from what I've heard, decently fast.
crazyjr
crazyjr's Avatar
11.20.2006, 10:18 PM
That would be me, yeah its a good setup. I'm running it with 12 cells , but might be going to 4s lipo's soon. Speed wise it runs great on a track and bumpy surfaces, but on smoother surfaces it might be a little slow. If you want more speed, go for the 8XL, there is another (i think Finnster, has this combo with 14 -16 cells NIMH). The only thing you need to do is to remove the middle wire from the esc plug and use a reciever pack or UBEC, I also changed the mamba plugs to 5.5mm to work with the wanderer i got.
