shood i get these?
overtki11
overtki11's Avatar
shood i get these? - 11.15.2006, 09:50 PM
hey guys,
i'm thinking of getting them FLM hybrid bulks that use 1/8 diffs for my emaxx....would the diffs from a hyper 7 fit? and also will the ratio be the same as my stock maxx diffs? or would i need to gear up or down on pinion tooth count?
i'm not using insane BL power..just the regular HV....so i figure the 1/8 diffs would laugh at the power put out by 4400 motor...haha.
initially though of just getting reg alu bulkheads to replace the stock plastic ones, but i know that my stock maxx diffs will die eventually, so buying a hopup alu diff and alu bulkheads and alu diff cases starts to add up....i can get a pair of 1/8 diffs fairly cheap thats why i'm considering the hybrid bulks...
any words of advice before i click "add to cart"?
cemetery gates
11.15.2006, 10:37 PM
Originally Posted by overtki11
hey guys,
Well, i am not sure if the Hyper 7 diffs will fit, most likely they will. I know the ratio of them is 3.31:1 as where stock maxx is 2.85:1. You will have to use a larger pinion to compensate...........
Bye:018:
coolhandcountry
coolhandcountry's Avatar
11.16.2006, 09:15 AM
I am not sure on the hyper 7 either. The ofna works I do know. I have used ue as well in them. They was a great bulks.
Peace!
Country
Help support the
Rc-Monster
Buy here
overtki11
overtki11's Avatar
11.16.2006, 09:52 AM
thanks for the input guys...
i take it that there's no "fitting" issues with these bulks? everything drops in nice and snug? or do they require a lot of shimming for the 1/8 diffs to fit?
neweuser
neweuser's Avatar
11.16.2006, 10:28 AM
I use the Hybrids with the UE 8 spiders and no shimming req'd. Dropped right in.
squeeforever
squeeforever's Avatar
11.16.2006, 05:19 PM
Leroy, Hyper 7 diffs should fit...Since it is the OFNA Hyper 7...Not to mention, I believe the UE diffs are pretty much the same thing as Hyper 7's. About like the UE shocks...
neweuser
neweuser's Avatar
11.16.2006, 06:10 PM
The Hyper 7's I are 1/8th diffs and should fit the Hybrid bulks.
