My Jammin CRT pix
Cartwheels
My Jammin CRT pix - 01.16.2007, 11:50 PM
I bought this CRT off ebay and converted it to BL. Just recently finished. It sure is a smooth running machine, very driveable. I'm using 10/51 pinion spur, but I may have to go down a tooth on the pinion though. The Ofna 51t spur is piggybacked on a Kyosho 46T spur.
ID:	2235   Click image for larger version
Name:	top plate.JPG
ID:	2238   Click image for larger version
Name:	bottom top plate.JPG
Cartwheels
01.16.2007, 11:53 PM
Here is a couple more pixs
ID:	2242   Click image for larger version
ID:	2243   Click image for larger version
andywpj
01.17.2007, 01:04 AM
Hi Cartwheels ,
good truck,
we have a lot people conv CRT to BL and with quark 125 esc.
but we have many problem about heat issue quark esc.
i think CRT too heavy, we try go up spur to stock 62T and 10T better now.
by thw way , which motor did you got.
squeeforever
squeeforever's Avatar
01.17.2007, 01:14 AM
The best way to solve the gearing issue is to use Hot Bodies Lightning Stadium Pro ring and pinion gears in the f/r diff.
andywpj
01.17.2007, 04:17 AM
hi,
You mean change F/R diff rate to 4.3 right ?
but what's to differ change spur and Pinion.
Thank you.
tom255
tom255's Avatar
01.17.2007, 04:54 AM
Yeah i think he thought exactly that...
Main advantage of this, you dont need to use HUGE spur gear and rise higher ur midle diff holderand etc
andywpj
01.17.2007, 05:57 AM
ok thank suggestion.
i'm gonna try it.
thank you.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.17.2007, 02:16 PM
You can't talk gearing without telling what motor and battery you have?
4s? What motor wind?
My CRT is just like yours, with MM, 4s lipos and a 1515 1700kv... and it does very well geared 12/52. I did put a fan over the motor/esc to lower temps but it was still ok without fans.
I assume you have a higher kv motor like the 2200... so the gearing would be different of course. But it doesn't matter where you change the gearing... diffs or spur/pinion. The overall ratio is all that matters.
Sylvester
Sylvester's Avatar
01.17.2007, 04:54 PM
Looks good!
The battery trays dont look the best, they look as if they would slip out. (batteries)
Than again, i think that is velcro you have there?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
pb4ugo
01.17.2007, 05:02 PM
I have never had a heat problem w/ my CRT running MM, 1950/7 and 4s lipo. Geared 11/46 with stock r&p. Why do others have to gear so low?
Sylvester
Sylvester's Avatar
01.17.2007, 05:13 PM
Hey pb4ugo, how is the 1950/7 on 4s doing? I will run a similar setup in a lsp. Thanks.
Losi 8ight e
pb4ugo
01.17.2007, 07:15 PM
I love it. A little slower than my nitros in top speed, but it rips out of the hole. Unfortunately the closest track is 2 hrs. away (until I start one locally) so I haven't raced against the nitros head to head, but it would be competitive. No heat or thermal issues, don't know my total run time w/ 8800 mah, but it's over half an hour. When I really want to impress someone I'll hook up 6s again (assuming I ever get my MGM back).
glassdoctor
TEAM FUSION
01.17.2007, 07:52 PM
I have also run 14/52 and it worked ok too... and was quite a bit more impressive to watch.
Cartwheels
01.17.2007, 07:57 PM
I guess I forgot to post some of the facts, The motor is a Neu 1515 2200kv and the bats are the new Max Amps 4s 4000 Mah. I'm not running any fans right now on the Quark, it would probably make a difference though. The battery trays were one of the hardest parts to figure out, because the pinion is so close, but they actually work very well. I've been in some wrecks and no movement what so ever. The velcro makes all the difference.
I'm happy with the speeds so far too. Even if I gear down a tooth it seems like it will still be very good.
Procharged5.0
Procharged5.0's Avatar
01.17.2007, 08:05 PM
Is the heatsink actually mounted to the plexiglass (or polycarbonate, etc.)???
I'm not sure it will be too effective in that configuration.
