Goodjumping Set Up For Revo
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
Goodjumping Set Up For Revo - 05.03.2007, 04:23 PM
Hi guys my revo has the tendency sometime to jump with rear end down in a situation that i was trying to clear up a long second hump,the rest of the other jumps are fine ,any suggestions are very much apppreciated,i do have a stiffer spring on the rear, but maybe not stiff enough?
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
BP-Revo
BMW M Power!
BP-Revo's Avatar
05.03.2007, 06:22 PM
Just tap the brakes mid air to clear it up.
My E-Revo jumps perfectly level 99% of the time, but every once in a while it gets a little tweak and I have to correct.
Gustav
Gustav's Avatar
05.03.2007, 06:43 PM
you could try less pack in the rear to speed up the rebound(bigger piston holes).If you're happy with it in most situations though you could just leave it and deal with it from the transmitter.
edit;hey,cross post,spooky,i was thinking he meant the rear was staying packed down on the face of the jump.
luvsrc
luvsrc's Avatar
05.04.2007, 05:46 AM
so i dont need to use stiffer sping to prevent the rear to go down while jumping bec ithought using a stiffer spring in th rear will make the truck the tendency to nose dive
Serum
Serum's Avatar
05.03.2007, 06:39 PM
Do you mean the rear gives a donkey-kick when it landed? i've seen this on other revo's. I think the shock locks up because of the rather small holes in the pistons. larger holes and thicker oil would help. the shocks lock up on the compressed oil that is pushed thru the small holes. It can't absorb the jump, so it just bounces. thinner oil would help too..
Don't know if this is your question/problem though?
Serum
Serum's Avatar
05.04.2007, 06:01 AM
does it donkey kick at landing? need more info..
luvsrc
luvsrc's Avatar
05.04.2007, 07:28 AM
What is donkey kick?
jollyjumper
RC-Monster jumper
jollyjumper's Avatar
05.04.2007, 07:34 AM
if i understand its when it kicks up the rear end after landing.
losi 8ight-t
xray xt8
luvsrc
luvsrc's Avatar
05.04.2007, 08:27 AM
it is when it is about to approach the jump, I full throttle then when it jumps into the air, the rear end is down more like in wheely position then it lands with rear tires first unlike what BP-Revo said his truck jumps in level position and lands in level both front and rear tires ,I'm thinking of putting stiffer spring on the rear to counteract it.Hope I 'm explaining it better
jollyjumper
RC-Monster jumper
05.04.2007, 08:36 AM
normally you shouldnt gun it in the air or on aproach.:p
losi 8ight-t
xray xt8
Serum
Serum's Avatar
05.04.2007, 11:12 AM
Nope, go for a 50 percent throttle 'in air' on the speed you are approaching the jump, that way it should stay flat.
neweuser
neweuser's Avatar
05.04.2007, 02:42 PM
that is correct, you don't want to keep it on full throttle after you leave in the air, but maybe half or so. When you keep on the throttle, it will start to make the truck travel going backwards. If you brake in the air, your truck will nose dive, you can correct your problem by just tapping the brake to level her out in the air.
Dafni
Dafni's Avatar
05.04.2007, 06:47 PM
Just work on your mid-air throttle skills and you'll be fine.
luvsrc
luvsrc's Avatar
05.04.2007, 07:39 PM
thanks guys
