Pros and Cons
GorillaMaxx360
GorillaMaxx360's Avatar
Pros and Cons - 06.16.2007, 11:39 PM
I was looking at buying a super brain 977 and i wanted to know your guys experience with it. I was going to get an ice but this charges 2 batteries at once and seems more economical for my 2 pack applications (Emaxx). with the brain i would cut charging time in half on some 2packs of lipos. does this charge max amps batts well? how easy is it to use? how many cells (lipo and nimah)can it charge at one time (per single battery plug, meaning for example if you where charging two batts up to how many cells could you charge on each lead). Any thing i should know and how does this compare to an ice because i can get it about one hundred bucks cheaper because i don't need a power supply.
Serum
Serum's Avatar
06.17.2007, 03:43 AM
If you can swing it, i would go for the 989.
GorillaMaxx360
06.17.2007, 08:48 AM
how much is it and have you had any experience with it.
hemicuda11
06.17.2007, 12:03 PM
It charges up to 3 cell lipo and 9 cell nimh on each channel. It has a lot of capability for the money and is easy to use, set the # of cells the threshold and start your done. However it does tend to false peak I have to set the threshold high to get a full charge which really isn't a problem. Great charger for the money if you don't plan on going over 3 cell lipo.
MetalMan
MetalMan's Avatar
06.18.2007, 12:34 PM
hemi, Rene said 989, not 977 :).
http://www.rc-monster.com/proddetail.php?prod=MRC_989
http://www2.towerhobbies.com/cgi-bin...&I=LXLCJ6&P=ML
hemicuda11
06.18.2007, 02:33 PM
Originally Posted by MetalMan
I was referring to the OP, he asked about the 977. Guess I should use quote more often.
Serum
Serum's Avatar
06.18.2007, 12:39 PM
Few bucks for great service.. :)
MetalMan
MetalMan's Avatar
06.18.2007, 12:58 PM
Yes, you are right.
miniGranis
06.18.2007, 01:26 PM
FYI The 977 can only do 2.5 amps on each channel in LiPo "mode" :-(
GorillaMaxx360
06.18.2007, 03:00 PM
is this true guys because that would take for ever to charge two lipos.
jhautz
jhautz's Avatar
06.18.2007, 05:58 PM
Yes its true. The 977 is a great charger for smaller packs, but it does top out at 2.5amps on a 3s lipo and 3 Amps on a 2s. Not exactly ideal for an 8000mah battery.
IMO the 989 is a much better chioce. Make yourself a y harness and charge your packs in series up to 4s or 5s or 6s in series. It even still has a limit of 7.1amps on 4s and 5.7amps on 5s.
You need to start getting into a much higher end charger to charge faster on large pack configuration like that though. The 989 is a great do it all charger. It will charge any battery you have (except a123).
I also really like the Extrema charger ($190-$200). But you need a separate power supply for the that. But it will do 5s at 7.5A if you have a 25A power supply or car battery to hook it up to.
Check out Brians Charger tool. It show you what you can expect from a charger. http://scriptasylum.com/rc_speed/_charger.html
to make it...
or break it...
Silent...But Deadly
miniGranis
06.18.2007, 03:05 PM
Trust me, my 8000mAh LiPos have been on the charger for 2++ hours now as I write this...
Serum
Serum's Avatar
06.18.2007, 03:12 PM
There are weaker chargers available though, for those who want to wait..
wallot
wallot's Avatar
06.18.2007, 06:09 PM
989 is great value more money but I expected bit more max charging power. 120W is not much
I am starting to be a big fan of TEMA SCD300 - fully manual charger (with some automatic modes) with 300W of charging power
http://www.telink.cz/en/katalog/charger_scd300.htm
but the price is bit high (around $350)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
06.18.2007, 06:58 PM
Yeah, 120w is not much, but it can charge 4s at over 8A, so it's not all that bad.
That charger is not much to look at, but the specs seem ok. Price is a bit steep though. I'd almost rather get two smaller but high current chargers. Funny how they don't list a Li cell count, only "49v". That equates to approx 11s. With a 300W limit, the outputs look like this:
Code:
Cell  Amps   Limited By
1s   10.0A   Current Rating
2s   10.0A   Current Rating
3s   10.0A   Current Rating
4s   10.0A   Current Rating
5s   10.0A   Current Rating
6s   10.0A   Current Rating
7s   10.0A   Current Rating
8s   8.9A    Power Rating
9s   7.9A    Power Rating
10s  7.1A    Power Rating
11s  6.5A    Power Rating
Needs a solid 40A @ 12v to run that thing to full capacity though. :eek:
