Has anyone ran a Neu 1521 in a G3R?
hyperasus
Has anyone ran a Neu 1521 in a G3R? -
09.06.2007, 05:31 PM
At 3.3" long would a 1521 be too long to fit a G3R?
hyperasus
Find all posts by hyperasus
2
hyperasus
09.06.2007, 06:24 PM
Nobody? Thats surprising.
Anyone know if the 1521 has a normal bolt pattern and 5mm shaft?
hyperasus
3
lutach
09.06.2007, 09:28 PM
Originally Posted by
hyperasus
They use a 4mm bolt as well.
lutach
Find all posts by lutach
4
gixxer
09.06.2007, 06:53 PM
I run a 1521 1y in my 8t. The bolt pattern is normal and it has a 5mm shaft. Not sure if you have enough room on that chassis though.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
gixxer
Find all posts by gixxer
5
crazyjr
09.06.2007, 07:42 PM
If i'm right, that motor has 6mm (1/4") longer than my 1515, wow you are going to have a time holding the front down
crazyjr
Find all posts by crazyjr
6
gixxer
09.06.2007, 08:14 PM
a 1515 is listed as 2.7" and the 1521 is 3.3", so its .6" longer.
gixxer
7
hyperasus
Can someone with a G3R and slipperential measure and see if a 3.3" motor will be too long?
gixxer did you get your 1521 from Mike?
hyperasus
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
