10.05.2007, 10:54 AM
Well, again that depends on a few things. Are you racing or just bashing about?
If you are racing, you will want to buy the smallest batt that will have enough energy to last the race + ~20% or so. Say for a 15 min race, I wouldn't go any lower than a 4000mah, but exactly how much you need will depend on alot as well. if you are racing now, how much mah you put back in a pack after the race? From there find a bat that has a high enough "C" rating. Note that they are rated for continous, and burst discharges will be higher (which the 100-120A peaks would be.) Don't go too low on the C, but don't feel you have to get a batt that will do 120A continous. A 20C 4000mah would work I would think. Get someting that does at least 80A continuous to be safe (and if you have more money, get the highest C you want to spend for, like 30C.)
If the motor an all weighs ~500g, I would shoot for a batt that is somewhere close, hopefully slightly lighter, like 400-500g. Trackpower, NeuEnergy, Thunderpower, others all have quality high-end batts if that is what you are really shooting for. Maxamps or TrueRcs smaller batts will also work if $ is a bit tighter. May have to go up a bit in mah to get the discharge you need tho, like a 5000 mah batt. I know TrueRc has a 5000 mah batt that does ~115a burst, and weighs 110g/cell (so 4S=~450g) and is only $90. At that price you could have a few for several heats of racing. Don't be shocked by the lowly 10C rating, as their cells are frequently underrated, which is a nice change.
If you are just bashing, don't worry too much about it imo. If the car drives ok, flys straight, go with whatever you want to spend
