ESC Capacitors
mwry13
mwry13's Avatar
ESC Capacitors - 11.05.2007, 01:20 AM
I just picked up some 35v 330 UF caps for my MM, and i forgot which way there soldered on... Anyone care to share how they went again?
would appreciate it.
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
Neu 2s 5000 Mah 30c Batteries
M11 DSSS
Airtronics 358
Socal
glassdoctor
TEAM FUSION
glassdoctor's Avatar
11.05.2007, 03:26 AM
Caps are marked with a "-" which is connected to the neg main power input.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
offroader
11.05.2007, 12:20 PM
Use a meter to see which side is -ve check for continuity between the negative side of the power and the solder points.
11.05.2007, 12:49 PM
And they should be soldered as close to the ESC as possible for max benefit. Here is a thread that shows how I did my Quark. I know it's a different ESC, but the principles are the same: http://www.rc-monster.com/forum/show...91&postcount=2
GriffinRU
11.06.2007, 12:32 AM
jokerjustin
RC-Monster Cheap Ass
jokerjustin's Avatar
11.06.2007, 11:33 AM
griffin ftw!
mwry13
mwry13's Avatar
11.06.2007, 09:42 PM
Whats the difference between caps with say a 330 Uf and the same voltage caps with like 1800 Uf... Is it better to be closer to whats stock on the MM? or should i go all out and get a big cap with a high Uf number?
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
M11 DSSS
Airtronics 358
Socal
BP-Revo
BMW M Power!
BP-Revo's Avatar
11.06.2007, 09:53 PM
uf is the capacity of the capacitor. Bigger the number the more energy they can store. Having one 2000uf cap is the same as having 20, 100uf caps. However, I believe having less caps is more efficient.
mwry13
mwry13's Avatar
11.06.2007, 10:01 PM
So would you say having 2 or 3 330 Uf caps is better than having 1 1800 Uf Cap or something in that range?
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
M11 DSSS
Airtronics 358
Socal
squeeforever
squeeforever's Avatar
11.06.2007, 10:12 PM
Originally Posted by jokerjustin View Post
i would say the more the better because the more surface area will help with cooling. but on the otherhand u have slightly higher resistance
Surface area of what??
Thats the opposite of what he said...
2x330=660
3x330=990
or just 1800Uf and you surpass have 2 or three, and with what he said about having less is more efficient, having 1 1800Uf is obviously more efficient and better. At least thats what I got from what he said...
jokerjustin
11.06.2007, 10:04 PM
jokerjustin
11.06.2007, 10:14 PM
i ment more cap surface area for better cooling
BP-Revo
BMW M Power!
BP-Revo's Avatar
11.06.2007, 10:16 PM
I assume he means the total capacitor surface area is larger, which reduces heat.
However, I personally have never had a capacitor heat up anything over room temperature. I used 3 25v, 2700uf capacitors wired in series with my HV4.5 and they added a significant amount of punch, as well as lowering my ESC temps a good 10* F.
squeeforever
11.06.2007, 10:18 PM
Thats what I thought he meant, but it didn't make any sense since they shouldn't heat up...
mwry13
mwry13's Avatar
11.06.2007, 10:27 PM
Ahhh thanks for the help guys... appreciate it... now if i can find my camera when i hit up the track on friday... ill post a small vid
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
M11 DSSS
Airtronics 358
Socal
