Align 600xl in revo on 4s-6s.... what esc?
Align 600xl in revo on 4s-6s.... what esc? - 12.16.2007, 06:46 PM
i wanna run the align 600xl motor in a E-revo with 4s-6s batts. what speed will i get with each? and what esc would work well?
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.17.2007, 01:47 AM
I would go with either the Quark 125, or one of the MGM controllers.
12.17.2007, 11:22 AM
well i was thinking about the MM and the polyquest 4s lipo. with a 30-50c discharge rate, that should be enough to make it really move.....right? i might use the $275 quark controller. but i was thinking about the kontronik jaxx 80-6-18. would that be a good choice?
BL-Power
BL-Power's Avatar
12.17.2007, 11:34 AM
I am also using the Jazz 80-6-18. Its really good controller, and it peforms very well, i've never had any signs of cogging. If you use a data recorder, you will see that you can't get more than 1300watts out of it on 4s Lipo. I am using mine on 6s Lipo and i have peaks up to 2000watts an the Jazz is still cool like a stone
Its a very nice controller
 Send a message via ICQ to BL-Power
12.17.2007, 11:38 AM
what motor are you using?
12.17.2007, 12:38 PM
Go quark, or the kontronic. The MM will not run the align 600, or any other outrunner(save for crawler apps). The quark works well for me, I actually used the roadster 65 on an align 600l in a 2wd emaxx. I would say that if you are going to run 5s that you could use the quark 80 or a mgm 90 amp esc to save some money. The align motor will not spin very fast on 4s so you will have some high gearing, and most likely need an esc with over 100amp rating. I ran my emaxx on 4400 5s 20c lipos and they stayed cool, as did the quark 65 and the motor. It was geared for around 40mph.
BL-Power
BL-Power's Avatar
12.17.2007, 01:02 PM
I was using a Kontronik Fun 600/15, then a Align 600L and now i'm using a Neu 1515/2.5D. They are all working fine with the Jazz!
12.17.2007, 01:54 PM
What did you think of the fun 600/15? Was it a good motor, better than a feigao? I am sure that the neu is better than the kon and align motors.
squeeforever
squeeforever's Avatar
12.17.2007, 04:07 PM
If I'm not mistaken, the MM will run outrunners.
12.18.2007, 11:59 AM
Yes the MM will, but not in a high load/high rpm application. It did not like the align motor and have seen it have issues with small outrunners in crawlers. I actually played with the programming on my friend's crawler and made it better. But it would still stall the motor sometimes and not be able to turn it over. I have had much more success with quark controllers for outrunner applications.
cart213
cart213's Avatar
12.19.2007, 10:50 PM
I just got a 600XL but haven't had time to try it yet. It will be paired with my Barracuda 125 in my MGT. Hopefully these two will play nice with each other when powered by 7s2p A123 cells. I'll get around to trying it during my Christmas break next week. My goal is to crack the 50mph mark.
