Power Switch Wires Came Off
E-Maxx King
Power Switch Wires Came Off - 02.03.2008, 02:22 AM
Where do they go?
83gt
02.03.2008, 01:34 PM
on the bottom of the circuit board where it sticks out of the side of the case. Best option for most is to solder the two points together. to heck the crappy switch.
phildogg
phildogg's Avatar
02.03.2008, 02:19 PM
Yeah I've had the switch come off also and just soldered it with no switch.
phil
Slash 4x4 163mph
drc rail 150 mph
phildogg6@yahoo.com
my youtube channel
E-Maxx King
02.03.2008, 11:52 PM
Right on top of those three wires? Those two little tabs? Which one goes where?
DrKnow65
DrKnow65's Avatar
02.04.2008, 12:48 AM
The switch wires go on the bottom side of the board, just between the red motor wire and the positive battery wire, opposite side of the board from the led's. Polarity is not important, it only makes or brokes the circuit. The black switch lead is closer to the red motor wire, if I remeber correctly. Both of my MM's have had the switch removed and the connections "bridged" with a bit os solder. (you can just get to the two pads for the switch wires with the MM assembled in it's case).
