Mugen MbX5 spur.
naftausa
Mugen MbX5 spur. - 12.06.2007, 06:38 PM
hi..
i'm going to covenrt my mbx5 fro Gp to Ep..
do u know if exist some plastic spur for the center diff????
i hate the sound of metal spur with the pinion....
MetalMan
MetalMan's Avatar
12.06.2007, 07:00 PM
There is no one-piece spur gear solution, but there is another way. Mugen makes an adapter plate for their diffs that allow an Ofna spur gear like this one to mount onto the diff:
http://www3.towerhobbies.com/cgi-bin...?&I=LXBM16&P=7
I think someone mentioned that the gear will need some modifications to fit. Unfortunately I cannot find the Mugen spur gear adapter part number, but it's out there.
The normal solution is a Kyosho plastic spur gear. That doesn't work because normal 1/8 diffs have a 6mm output shaft, but Mugen diffs use a 5mm output.
As long as you use a hardened pinion, there really isn't any problem running a steel spur with a steel pinion. Many of us have had great luck doing so.
macr0w
macr0w's Avatar
12.06.2007, 11:47 PM
Originally Posted by naftausa View Post
hi..
I'm in the same boat as you. I think I'm just going to get a hardened pinion and keep the Mugen diff on mine.
What motor mount are you going to use?
Cartwheels
12.07.2007, 12:53 AM
Here is that part #MUGZMT008. This adapter is getting harder to find. Also, it takes some very minor dremeling in the holes of the Ofna spur gear to make the screws fit in the hole staight.
naftausa
12.07.2007, 06:50 AM
someone have a mugen mbx5 with plastic spur??
i really hate the metel-metal sound..
i think also that the pinion will have a longer life..
must find a plastic spur..
Cartwheels
12.07.2007, 06:25 PM
https://www.ssl-stormerhobbies.com/c...s&pn=MUGZMT008 Here is the adapter. They must be doing away with it. No one seems to have it in stock anymore. This with the Ofna 51t spur is a pretty good way to go.
naftausa
12.07.2007, 07:34 PM
i'll looking for a specific spur ofna model using the adapter??
glassdoctor
TEAM FUSION
glassdoctor's Avatar
12.07.2007, 11:49 PM
FWIW, I'm might have found something else that will work... that's all I can say at this point, after failing last time I tried to get a special item like this. If I find anything I will definitely let you know.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
MetalMan
MetalMan's Avatar
12.08.2007, 01:39 AM
Look at my first post, the link to the spur gear is there.
Cain
02.01.2008, 03:27 PM
I run an electric MBX5 that came with a hot bodies diff and uses the kyosho 46T spur. May be the easiest way to go.
Serum
Serum's Avatar
02.01.2008, 03:44 PM
The hardened pinions are good as they are, you can simple use those with the steel spurs.
glassdoctor
TEAM FUSION
02.02.2008, 12:02 AM
You guys want a plastic spur? Or is everyone happy with the metal-on-metal?
Are the metal gears kinda noisy???
I tried to get a shop to make a plastic CRT.5 spur but they drove me nuts and I gave up. Maybe I should try again and get a Mugen too... lol
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
