1) Excellent Recharge Performance
The thin battery recharges to 80% of full capacity in only a minute. Total recharge takes only a few more minutes.
2) High Energy Density
Small and light, the new battery offers a high level of storage efficiency. The prototype battery is only 3.8mm thick, 62mm high and 35mm deep and has a capacity of 600mAh.
3) Long Life Cycle
A prototype of new battery (a laminated lithium ion battery with 600mAh capacity) was discharged and fully recharged 1,000 times at a temperature of 25 degrees centigrade and lost only 1% of capacity during the test.
4) Temperature
The new battery operates well in extremes of temperature. It discharges 80% of its capacity at minus 40 degrees centigrade, against 100% at an ambient temperature of 25 degrees centigrade, and loses only 5% of capacity at temperatures as high as 45 degrees centigrade after 1,000 cycles. These characteristics assure the wide applicability of the battery as a power source for products as diverse as hybrid vehicles and mobile phones.
5) Eco-friendly Battery
The new battery can quickly store energy produced by locomotives and automobiles. This speedy and highly effective recharge characteristic of the battery will support CO2 reduction, as the battery can save and re-use energy that was simply wasted before.
You can read more
here, seems very interesting..
