Oiling motor bearings
ilpufxit
ilpufxit's Avatar
Oiling motor bearings - 04.07.2008, 12:34 PM
My 8ight thermalled last night. It normally won't even get hot. I'm running a Neu 1512 2.5 d/f on 5s. Quark 80b. 14/46. It seemed to be hard to roll even with the power off. When I pulled out the motor to see what was tight, it was the armature. Not really tight but enough so I could tell there was more drag than magnetic resistance turning the pinion by hand. I applied some bearing oil to both ends of the shaft and after a little spinning it seems much more free, still notchy from the magnets but no more drag.
So, my question is, should I normally expect to have to oil those bearings and if so, how often?
neweuser
neweuser's Avatar
04.07.2008, 01:28 PM
I put just a dab every 5 runs or so. Clean them, dab them.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.07.2008, 01:29 PM
I put a drop, once a month... and let sit for a day... for absorbtion.. and then wipe off the excess oil.. I use the prolong precision oil... and it's been working for me..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
bdebde
That's All Folks!
bdebde's Avatar
04.07.2008, 03:30 PM
Some manufacturers say do not lube motor, I know the instructions with my Plettenberg Big Max said that.
Serum
Serum's Avatar
04.07.2008, 04:31 PM
I know my bigmaxx had play on the bearings after 4 dumps of the 16 cells nimh packs!
aqwut
aqwut's Avatar
04.07.2008, 04:54 PM
you haven't moved to Lipos yet Serum...
only one feigao failed on me.. but that was because the motor popped a bit and I keep on running it.. of course I did not know of this till after....
Serum
Serum's Avatar
04.07.2008, 05:00 PM
This was a year or 4 back when this happened.
So i emailed plettenberg about it, but the bearings are no part of the warranty.. (understandable)
