I got a problem, need help!
Redneck427
I got a problem, need help! - 04.18.2008, 07:08 AM
Ok, ive got a 4wd 1/10 electric buggy with a traxxas reciever, traxxas digi hi torque servo, mamba 4600 motor and sidewinder esc.
Whats happening is, Im turning left sharper and sharper and everything is perfect until I make that last step all the way to the left then the throttle stutters and wont hardly go, but then I turn back to the right a tiny bit and everythings perfect again. Its not mechanical binding, and I tried different transmitters with no change.
Anyone ever hear of this or have it happen to them?
83gt
04.18.2008, 07:28 AM
I've seen nothing but binding that could cause such an issue. As a workaround, you could set the steering endpoints to stop short of the place that causes the problem.
J.
DrKnow65
DrKnow65's Avatar
04.18.2008, 10:37 AM
get a ubec, or pull straight batt power for the steering servo if you are running 7.4v. The high torque servo is propably pulling more amps than the sidewinder internal bec can provide. A good way to know if this is the problem is to hook a voltmeter to the red/black wires going to the steering servo and watch the voltage when the problem happens. The voltage should not get below 5v. You can use a pair of paper clips to "back probe" (stick in the connector while it's plugged in), just be real careful not to short the paper clips togeather :)
Redneck427
04.18.2008, 11:08 AM
thanks, that makes sense. my radio is just a simple traxxas one, no adjustments except trim. now the only problem is finding room in that frekin thing for a ubec.
skellyo
skellyo's Avatar
04.18.2008, 11:10 AM
Get a Castle BEC...they're tiny.
http://www.castlecreations.com/products/cc_bec.html
