Deleted Nitro Parts when converting
Rcaddict
Deleted Nitro Parts when converting - 04.17.2008, 09:33 AM
Out of curiosity, I went through my 8ight parts manual and listed out all of the parts that get tossed when converting from nitro to electric. I also broke down the motor into it's individual pieces. There are close to 125 parts that are no longer needed and probably more that I didn't think about. Feel free to add to the list if I left anything out. The biggest thing I hear from nitro racers is that they like the sound, smoke and smell. All of that comes at the cost of many, many points of failure.
A9154 Motor Mount
A9104 Clutch Bell Screw and washer
A6949 Clutch Bearing x 2
A9117 Clutch Bell
A9103 Crank Nut and Collet
A9104 Clutch Shoe Posts x 4
A9108 Clutch Shoes x 2
A9107 Clutch Shoes x 2
A9114 Clutch Springs x 2
A9115 Clutch Springs x 2
A9165 Muffler Standoff (2 parts)
A9160 Fuel Tank
A4424 Fuel Tank Posts x 2
A9316 Fuel Line Clips
Fuel Line
Fuel Filter
A6204 Tank Screws x 2
A6350 Tank Screw Washer x 2
A9313 Fuel Tank Grommets x 2
A9160 Fuel Tank Lid Pin
A9161 Fuel Tank Lid and Spring
A4422 Tank and Filter Guard
A6277 Guard Screws
A3541 Brake Shoes and Posts x 4
A3540 Brake Discs x 2
A4422 Splash Guard
A9166 Brake Linkage
A3544 Brake Cams x 2
A6109 Cam Clips
A9150 Brake Clip
A6227 Brake Linkage Hardware (23 parts)
A6232 Screw
A6254 Screw
Throttle/Brake Servo
A6206 Servo Screws x 4
A6277 Screws x 2
Air Filter
Filter Assembly(5 parts)
Muffler
Exhaust Gaskets
Header
Header Springs
Starter Box, Batteries and Charger
Fuel
Fuel Bottle
Glow Driver and Charger
Rx Battery
Motor
Crankshaft
CrankCase
Piston
Sleeve
Head
Head Button
Glow Plug
Head Gaskets
Needle Assembly (4 parts)
Bearings x 2
Carb Body
Carb Seal
Carb Retainer
Piston Pin
Connecting Rod
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
04.17.2008, 09:59 AM
I'm sure sick of all those points of failure and having to clean my car so much. I can't wait for the MMM so I can finally finish my savage. Silly little things stuff you up with nitro like tonight I discovered a hole in my fuel line.
