Neu motor question
Jbreddawg
Jbreddawg's Avatar
Neu motor question - 04.17.2008, 09:15 PM
Probably a simple question but Id much rather ask before instead of after
I just received a Neu 1515 2.5 D , what a beautiful motor !! Anyhow, no flatspot on the shaft , whats the best way to put one there ? Thanks, Jerry
The wheel may be turning, but the hamster's dead .
macr0w
macr0w's Avatar
04.17.2008, 09:21 PM
Put a grinder head on your Dremel tool and be careful. That's what I did.
If you put the motor in a plastic bag you can poke the shaft thru the bag to keep debris from getting in the motor.
Again be careful.
Chapito
04.17.2008, 09:22 PM
I use a dremel with spiral cut bit. Pretty sure a stone or cylindrical rasp will work as. Only needs to be as wide as the set screw and a millimeter or so deep.
Jbreddawg
Jbreddawg's Avatar
04.17.2008, 09:24 PM
thanks !!
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.17.2008, 10:18 PM
I tape the whole motor up.. put the shaft in a vice, and file it down.. takes about 10 seconds of filing...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
No need to grind your neu
Jammin
Jammin's Avatar
No need to grind your neu - 04.17.2008, 10:23 PM
Hey man, you don't have to grind that shaft at all. Just use a little green locktite on it. Thats why there isn't a flat spot already on the shafts. Thats what castle creations told me.
