Hybrid Diffs
azjc
Hybrid Diffs - 04.29.2008, 06:02 PM
For the users of the Hybrid Diffs what weight lube are you using?, I will be using a Revo tranny locked in 2nd gear w/CD
GorillaMaxx360
GorillaMaxx360's Avatar
04.30.2008, 04:55 PM
i run 10k in the front 7k in rear that should be a good starting point. the thicker fluid in the front gives you more on power steering and less off power.
04.30.2008, 04:57 PM
I am using 10K front and 5K rear in my t-maxx conversion
TDC57
TDC57's Avatar
05.08.2008, 07:20 PM
I'm using 7000 in the front and 5000 in the rear. Mike recommended this setup (for what it worth). As stated above thicker fluid in the front gives you more on power steering and less off power.
Hope that helps..
Have a great one.
Nothing!.. Hahahahaaa..
