MGM esc cap problem ( high res )
emaxxnitro
emaxxnitro's Avatar
MGM esc cap problem ( high res ) - 04.17.2011, 09:27 PM
http://i183.photobucket.com/albums/x...090107_002.jpg
http://i183.photobucket.com/albums/x...090107_003.jpg
The pictures say 1000 words
808E
emaxxnitro
emaxxnitro's Avatar
04.17.2011, 09:41 PM
Should i try and re solder it or should i replace the capacitor?
808E
04.17.2011, 09:53 PM
Replace it. You may be able to solder it so it is workable, but the heat so near the device may not be good.
emaxxnitro
emaxxnitro's Avatar
04.17.2011, 10:03 PM
can you show me a cap that will work?
Im good with the SMT stuff i do work soldering on phones all the time
It still works even with the cap disconnected it just cuts out
808E
sikeston34m
sikeston34m's Avatar
04.17.2011, 10:30 PM
Hi,
The critical numbers that you have to look for are:
105C - this is the maximum operating temperature - also points toward the fact that it is low esr.
50v - maximum operating voltage
390uf - universal farad number or capacity. This number can be larger but not smaller.
Looks like you need to match the diameter also, length doesn't matter.
I would Ebay it.
emaxxnitro
emaxxnitro's Avatar
04.17.2011, 10:37 PM
so nothing i could pick up at the local radio $h*t?
808E
brainanator
brainanator's Avatar
04.17.2011, 10:59 PM
you might be able to find it at radio shack or another local electronics store. Go take a looksee.
emaxxnitro
emaxxnitro's Avatar
04.17.2011, 11:00 PM
yea i think i will tomorrow.
808E
04.17.2011, 11:26 PM
You won't find caps rated for 105*C at RS, only 85*C, and those are not sufficient....
emaxxnitro
emaxxnitro's Avatar
04.17.2011, 11:28 PM
Hmmmm where then? linkies?
808E
brainanator
04.18.2011, 01:58 AM
ah, I didn't know the rat didn't carry high temp caps :)
brainanator
04.18.2011, 02:06 AM
I ordered my caps from digikey, they have a funky checkout system....but I found them to be the cheapest after shipping was factored in for buying single caps and what not....
Here is the search screen on their site, http://search.digikey.com/scripts/DkSearch/dksus.dll
I tried linking you to a search I already did, but it didn't work...pretty easy search options though. Each cap should be under a buck.
emaxxnitro
emaxxnitro's Avatar
04.18.2011, 12:23 PM
Eh i just decided to fix it. It seemed easiest
http://i183.photobucket.com/albums/x...090107_004.jpg
808E
