e-maxx brushless servo
jalodo56
e-maxx brushless servo - 01.23.2009, 05:33 PM
Hello I have an e-maxx with medusa 1600kv 60mm on 6s + MMM, and servo of steering is a hitec hs-985mg. Can I use this servo on e-maxx without servo saver?
regards
Rivermaxx
01.23.2009, 06:32 PM
Sure as long as you dont mind breaking it when you hit something wrong.
bensf
01.23.2009, 06:35 PM
Whats wrong with using a servo saver?
ssspconcepts
ssspconcepts's Avatar
01.23.2009, 06:56 PM
Rivermaxx is correct. The servo saver absorbs the shock from impacting bumps, objects, and other hazards that are in your way and prevents damage to your expensive servo (ie., "servo saver").
From Titan Maxx
From Titan Maxx
From Titan Maxx
jalodo56
I prefer use without servo saver because the steering are more precise, I used the servo saver of t-maxx 2.5 and a hot racing servo saver and these servo savers are imprecise.
what servo saver could use? it is not too expensive.
Regards
jalodo56
01.23.2009, 06:58 PM
the UE IV is too expensive for me.
bensf
01.23.2009, 07:02 PM
You could also see if you can replace the spring in your current one for one a little stiffer.
jalodo56
01.23.2009, 07:24 PM
Whit this servo saver can I work fine?
http://cgi.ebay.es/NEW-3-3-T-MAXX-ST...3A1|240%3A1318
ssspconcepts
01.23.2009, 07:33 PM
I used to have one similar to that...it was made by Proline. It should work fine as long as your truck is not too heavy.
jalodo56
01.23.2009, 07:38 PM
my truck is 10lbs is good or bad this servo saver
Work or not??
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Work or not?? - 01.23.2009, 08:10 PM
That servo saver will work ok, but not as good as the gen IV UE servo saver. You have to work within your means $$$ and that is that. So if that is what you can afford, then that is what you have to work with. Any other option is only going to work so much. If you want perfection, then save your moeny and get the UE gen IV. With any luck UE might get back to making them again this year. Good luck with your endevour.
