motor Help!!!
electric
electric's Avatar
motor Help!!! - 06.20.2008, 06:50 PM
Just converted a MBX5T and running it on a feigao 9xl from my revo and when i put the motor in the mbx5t it had serious cogging and want to know is there a fix if not what is the best motor combination for it looking at neu's and don't know on what ESC to run with a neu.
Thanks for help
War Damn Eagle
azjc
06.20.2008, 06:54 PM
Thanks for help
what ESC are you running with the 9XL
electric
electric's Avatar
06.20.2008, 07:11 PM
running a mamba max
War Damn Eagle
azjc
06.20.2008, 07:15 PM
check your software and make sure you have 3.05 for Castlink and V1.17 for the firmware you can pull up the MambaMax software on your computer to find out
electric
electric's Avatar
06.20.2008, 07:22 PM
what am i finding out if i pull it up i don't think my computer has that.
War Damn Eagle
jayjay283
jayjay283's Avatar
06.20.2008, 07:39 PM
if you plug your mamba max controller into the PC and click the folder in the castle link program that says software it will tell you firmware= v1.17 or 1.16 or older, The icon on your PC for the castlelink shoud say v3.051 under the castlelink symbol. He is saying the firmware v1.17 has fixed alot of cogging issues and to make sure you are updated to the latest version 1.17. Yes i type too much
electric
electric's Avatar
06.20.2008, 09:25 PM
it does say v3.051 but my computer will not let it open castlelink work.
War Damn Eagle
Patrick
Patrick's Avatar
06.21.2008, 12:26 AM
What's the gearing in the MBX5T? Is it a similar final drive ratio to what you used in the revo? Overgearing can be one thing that causes cogging.
The mm software could help for sure, but if the same setup worked without cogging in the revo then I'd also look for things that could have changed when putting in the mugen, like the gearing, smoothness of the drive train, and that none of the plugs and connections are loose.
