Battery Straps
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Question Battery Straps - 06.19.2008, 12:44 AM
What is the strongest velcro battery strap out there? I just snapped a new Gorilla Battery Strap after 1 run and was wondering if there is anything stronger?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.19.2008, 12:49 AM
Bunnings have velcro roll stuff with hook on one side loop on the other. A bit harder to get tight but it seems pretty tough not that I have been able to test it.
I hate bunnings but sometimes I can't avoid it.
lutach
lutach's Avatar
06.19.2008, 12:50 AM
You could look for some industrial velcro. I know Home Depot sells a nice wide velcro that are super strong. I bought the white colored ones and they are great.
Edit: Forgot you are in Australia and didn't even ask if you have Home Depot there , sorry. You can find the velcro in most Hardware stores.
droopy
06.19.2008, 12:53 AM
Head down to your local upolstry shop and get some industrial use velcro. I use to build boats and we used it there the only way you will break that is with a knife plus it has huge holding power.
DRIFT_BUGGY
06.19.2008, 01:02 AM
Yeah, ill head down to my local hardware store and check out what they got, just sucks as right now it is school hour traffic and the store is accross the other side of town
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
06.19.2008, 02:20 AM
Went to Bunnings but they only had small rolls that you wrap around electrical cable. Have to try a few more shops tomorrow
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
06.19.2008, 02:24 AM
Thats the stuff I think I am using but it is an inch wide.
DRIFT_BUGGY
06.19.2008, 03:22 AM
Yeah, there was 1 box empty but didn't take notice of the width, it was 250mm long but didn't notice the width
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
tc3_racer_001
tc3_racer_001's Avatar
06.19.2008, 05:03 AM
one wrap straps by velcro. super strong, but thin (around 20mm wide i think) but u loop it over a few cm, and i challenge anyone to rip it apart. strongest, but then again, industrial stuff may be stronger again!
good luck.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Shark413
Shark413's Avatar
06.19.2008, 02:12 PM
Hi, I had the same problem. I found these and they hold up well, they are extra heavy duty velcro straps. They come in several different lengths, but I normally cut them in half, use a soldering iron, and put a hole in the ends (the heat seals the edges of the hole and makes it stronger). I then clamp the ends down to my battery tray/box using large washers that have a rubber gasket (so they don't cut into the velcro). Or you can get one that is long enough to wrap completely around your battery. Just keep in mind that these straps are thicker than normal velcro.
http://www.mcmaster.com/
Part # 3955T72
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
VintageMA
VintageMA's Avatar
06.19.2008, 02:47 PM
I actually use the velcro straps for wrapping computer cables in data centers (free because I work in one ;) ), but I haven't had a single problem with them very strong. You can get them at any computer store.
“Everyone has a right to be stupid; some people just abuse the privilege.”
aqwut
Brushless Heavy Weight....
aqwut's Avatar
06.19.2008, 10:47 PM
I use the HD velcro for wrapping heavy stuff... works great...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
