For those of you using a mm esc w/GriffinRu's mod 1 done, any probs on 5s? -
06.21.2008, 06:02 PM
I want to run my mm on 5s. I run it now on 4s and w/the mod 1 done and it runs great. I do not want to push it too hard on 5s
06.21.2008, 07:27 PM
Ran mine on 5S with the mod one done in a rustler with a medusa 2200....zero problems and I ran it pretty hard; as hard as you can in a rustler. Now running 6S with it and again zero problems.
06.21.2008, 07:29 PM
I run my Standard MM on 5s, no problems whatsoever
06.21.2008, 08:01 PM
I cooked my first mod1 mm on 5s.
Not really the esc or griffin's fault. I got a rock stuck in the pinion/spur while at full throttle. I sent it back to him and he had a look. Supposedly the mm had alot of solder in one area, and the intense heat that was created by full power going into a stalled motor caused the solder to melt and bridge two phases, thus smoking the esc.
I had him do another and have had great success with 5s.
06.22.2008, 09:34 AM
It's up to 5s I go!!!
06.22.2008, 10:32 AM
YAY your gonna love it..
06.22.2008, 10:55 AM
How much does Artur charge to do the stage 1 mod?
06.22.2008, 11:09 AM
If you want the mod done pm him. I had other issues w/mine when I sent it to him so it cost me more. It is well worth the money he chargers...he does great work.
06.22.2008, 11:18 AM
from what has been posted here you can disable the LVC and a stock MM will arm and you will be able to use it, you will either have to use an external LVC or have a lot of confidence in your abilitity to not run your rig too long
Team Thermal Racing
06.22.2008, 01:04 PM
Can a MM run 6s A123 with a UBEC and some bigger caps?
My Rides:
Tamiya Dark Impact - Team Losi Micro B - Cen Mini Madness - Soon to be BL Xray XB8 TQ
