need mgm 16018 help
satan'struck
satansbackyard666
satan'struck's Avatar
need mgm 16018 help - 06.20.2008, 12:01 AM
hi guys, i just received all the stuffs from mike and they're very very nicebut i need some help from you guysit seems like that the mgm16018 that i got from mike is a newer version and all the wire came in pairwell, i'm using 18 cell NiHM battery, and a tekno rc ed 1515 1y/fcould any of you guys tell me which wire to which...for example, the mgm got 2 red, 2 black, and 6 yellow wiresi believed those 2 red and 2 black wires are for the battery, and those 6 yellow wires are for the motor, RIGHT??? and i think since i'm using 18 cell battery(2 packs of 9 cell, so i'm able to do 1 or 2 plug!), am i suppose just put 2 red together, 2 black together, and to a battery plug??? and about those 6 yellow wires to the tekno motor, MAN I'VE NO IDEA so, i do really need help to figure that out and i hope that you guys will be able to help me, THANKS A MILLION IN ADVANCE!!! samsam from Hong Kong!
ID:	4826   Click image for larger version
ID:	4827   Click image for larger version
bdebde
That's All Folks!
bdebde's Avatar
06.20.2008, 12:58 AM
2 reds to battery +, 2 blacks to battery -, 2 each yellow wires (pairs on top of each other) to each motor plug. You are going to need 5.5 or 6.5 connectors to get all the wires in.
satan'struck
satansbackyard666
06.20.2008, 01:13 AM
since the motor got BLUE, RED, and YELLOW WIRE, which to which???i mean in the THIRD PIC, let say the LEFT TOP/BOTTOM SET of wire to which COLOR WIRE OF THE TEKNO RC ED 1515 1Y/F MOTOR???thanks, bdebde.
Desmo
06.20.2008, 01:29 AM
It dosen't matter on the motor wires. What ever order you want will work. If it runs backwards then just switch any two wires(two pairs). Just keep the pairs together.
satan'struck
satansbackyard666
06.20.2008, 04:20 AM
hi desmo, do you mean set#1 to blue motor wire???
set#2 to red motor wire???
set#3 to yellow motor wire???
and i got some of those hyperion 6mm gold bullet connectors, do you think is good enough??? thanks!
P.S. do you like my other RC's???
ID:	4830   Click image for larger version
david lamontagn
06.20.2008, 06:24 AM
don't understand why the wire is double on the 16018, i think you don't recieve a 16018, and you're very lucky, because you've paid for the 16018 and i think you have recieve a bigger one, like a 22418
Lucky guys
wallot
wallot's Avatar
06.20.2008, 07:07 AM
double wires are standard on mgm car controllers. when I was ordering my esc I asked for single wires as they are thick enough to handle the current
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
Desmo
06.20.2008, 08:30 AM
Yes that will work, 6mm bullets are good
david lamontagn
06.20.2008, 09:15 AM
I've order two 16018 last winter and they came with single wires. Maybe it's new feature from the newer batch who exit this spring.
If it's standard, it from last few week/month.
satan'struck
satansbackyard666
06.20.2008, 11:08 PM
guys, i heard this from my friend who own a hobby shop ...well, he told me something like this...say after you got up to top speed and when you want to slow down, you can't just slow down or give break to slow down, he told me that i've to kind of tap the grip several time to slow down, and this really confuse mehow do you guys slow down when using the mgm 16018??? thanks,sam
Desmo
06.20.2008, 11:19 PM
Mine slows down like most normal speed controls. It will coast in netural or brake when you hit the brakes. It will go into reverse after it stops.
satan'struck
satansbackyard666
06.20.2008, 11:25 PM
thanks for all the info, will see what's up after my first run if the xt8 still alive
Desmo
06.23.2008, 01:07 AM
run it yet?
satan'struck
satansbackyard666
06.23.2008, 03:48 AM
sorry desmo, i don't think i'll be able to finish the xt8 in a few days cause i'm for these few weeks and the rest of my time i need to spend with my wife and baby, but i think i can get it done within a week or max two weeks, so by that time i'll post some pics and tell you guys how's my xt8 doing!
Mgm 160/18
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Mgm 160/18 - 06.23.2008, 04:27 AM
I may be wrong, but it seems to me that your MGM controller came with double wires for running dual batteries and dual motors if you wish to use that configuration. If not then you can just cap the second set of wires leaving them dead ended. That is the only reason I would imagine having dual wires.
