Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
My revo conversion
George16
Supermaxx
George16's Avatar
My revo conversion - 11.03.2008, 08:35 AM
Well, I decided to convert my 2.5R revo into brushless. It will be powered by a Neu 1515 1Y and MMM combo. However, while waiting for the motor to arrive (though I can transfer the TeknoRC Neu 1515 1Y from the gmaxx), I decided to start assembling the truck.
Installed the Tekno RC conversion kit I bought from James (lincpimp):
MMM V3:
The TeknoRC conversion kit elektri-clutch uses a 2-shoe clutch system. I don't want to run this 2-shoe clutch with a 1515 1Y. Instead, I took out the stock clutch and installed my UE 4-shoe clutch from my supermaxx (retired from bashing and racing duties).
TeknoRC elektri-clutch:
Diameter of the flywheel mounting hole (elektir-clutch):
UE 4-shoe mounting hole diameter:
That's only a difference of .02mm.
Continued on next post
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
George16
Supermaxx
George16's Avatar
11.03.2008, 08:42 AM
Flywheels side by side:
UE flywheel with the stock clutch nut, elektri-clutch shaft, and collet:
Carbon shoes and .9 springs mounted:
Still plenty of room to access the setscrew:
Complete assembly:
Side by side with the stock:
See next
Revo with OS .18TZ
George16
Supermaxx
George16's Avatar
11.03.2008, 08:44 AM
Complete assembly:
Final measurement:
UE 4-shoe clutch, Kyosho 17T narrow CB:
Stock:
I will be grinding the lip on the 4-shoe flywheel tomorrow. The lip itself is about 2mm so after grinding it off, it will be about the same with the stocker. The UE 4-shoe clutch also used the e-clip just like the stock clutch.
My assortment of clutches/flywheels etc next to the assembled 4-shoe elektri-clutch:
Feedback is greatly appreciated.
Revo with OS .18TZ
E - Cluch
BAD 1
E - Cluch - 11.03.2008, 03:25 PM
Nice set up. Thinking of same set up for my Muggy. Have 1515-1y & MMM. Talked to R C Monster Mike about Motor mount & Bat tray. He also suggested 1515-3d. Running E-REVO w/ 1515-1y, MMM, 2-7.4 8000 Max Amps lipo, plus other racing mods.
Name:	New  Painted Body on E - REVO 018.jpg
BAD 1
11.03.2008, 03:28 PM
Will try to send more pics. This is all new to me sorry.
BAD 1
11.03.2008, 04:23 PM
Pics.
Name:	New  Painted Body on E - REVO 015.jpg
ID:	5754   Click image for larger version
Name:	New  Painted Body on E - REVO 001.jpg
ID:	5755   Click image for larger version
Name:	New  Painted Body on E - REVO 019.jpg
YogyBrushless
11.03.2008, 06:09 PM
nice setup, i am in the process of doing the same to my revo 2.5r, just recieved my conversion today :D
George16
Supermaxx
George16's Avatar
11.03.2008, 06:24 PM
I still have to test-fit the motor mount/clutch after I grind off the lip at the back of the flywheel. I might have to yank off the 1515 from my gmaxx for test-fitting.
I'll be running 4S on this truck once I receive my new lipos from neumotors.
Revo with OS .18TZ
TruckBasher
TruckBasher's Avatar
11.03.2008, 08:35 PM
Nice Lito another conversion. Is that MMM the replace you got from CC or you bought a new one. Mine still hasnt reached CC ...
We'll be watching this....
E-Slayer direct drive to diff
George16
Supermaxx
George16's Avatar
11.03.2008, 10:59 PM
Jeff, it's the replacement MMM. Right now, I'll just leave Luciano's ESC on the Emaxx and just transfer the motor until I receive another motor.
Revo with OS .18TZ
jordan...
one.five.two.seven
11.04.2008, 06:12 AM
Looking good Lito, i still really like those conversions, more so than the actual E-revos, seems sturdier with the metal chassis. Can't wait for updates
BAD 1
11.05.2008, 03:07 PM
I also have a REVO 3.3 w/21 OS that i race when Electric is not allowed. I am in the Sportmans class and by far the best driver but i can cartwheel, back flip, front flip, and tumble and twist with the best of them. My point is that its a REVO plastic or metal nothing twist or broke. What really attracted me to the E was the battery compartments which i wish were a little bigger. Biggest bat that i could fit are Max Amps 2s 2p 7.4 8000mil which I am sure will not last for 30min mains or longer. I still think that it still easyer to change out batteries then to restart nitros IMO.
Name:	R C X Games 2008 170.jpg
ID:	5760   Click image for larger version
Name:	R C X Games 2008 215.jpg
ID:	5761   Click image for larger version
Name:	R C X Games 2008 232.jpg
George16
Supermaxx
George16's Avatar
11.05.2008, 06:23 PM
Here are some pictures of the tranny I modified for the brushless revo. I converted the revo 2 speed to a single speed locked in 2nd gear using an adapter plate I bought from Oomp(one of the guys over at traxxas forum).
Single speed adapter plate:
It was designed for the plastic 2nd gear so I have to dremel the RRP 2nd gear to make it fit.
I also drilled the shaft to 2.5mm so I can use a bigger pin(stub axle pin) for added strength:
Side by side with stock RRP:
Revo with OS .18TZ
George16
Supermaxx
George16's Avatar
11.05.2008, 06:25 PM
Some more pictures:
1st gear removed:
The assembly:
The top shaft hole was also enlarged to 2.5mm in order for me to use a bigger diameter pin. I used the revo yoke setscrew custom-cut to size.
The flywheel after grinding the lip:
Revo with OS .18TZ
Semi Pro
Semi Pro's Avatar
11.05.2008, 08:26 PM
looks good so far
