stripped 1/8 buggy wheels????
rootar
rootar's Avatar
stripped 1/8 buggy wheels???? - 07.21.2008, 12:18 AM
has anyone else done this? i was cleaning it up getting it all packed up to take on vacation and i find one that is stripped completley round and another looks almost as badd. I KNOW the wheel nuts were tight i checked them every run ? what gives? these are BRAND new proline wheels......
kevin23
07.21.2008, 12:36 AM
I had a set of the jconcepts rulux wheels do this first run,not common but I have seen it.
I have also nboticed if you gorilla the nuts on like I do,you actually make the hex turn a little in the wheel,but if you don't tighten,they loosen up.Catch 22
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
07.21.2008, 01:00 AM
I honestly think the proline wheels are a bit soft around the hex. The plastic is probably designed to be flexible to absorb impacts and provide better traction but around the hex they can be fairly easy to strip. The other thing that will do it is if the ribs on the inside of the wheel can catch on the arms or if something goes into the wheel and jams between the ribs and arm.
Hakan_J
07.21.2008, 05:36 AM
I have seen this too on proline wheels! Not very helpful perhaps but at least you know your not alone! :)
AE RC 8FT
KO Propo EX 10 Helios
Tekno NEU 1515 1Y
Mamba Monster
TrueRC 4s 8000 Mah
rootar
rootar's Avatar
07.21.2008, 07:57 AM
yea glad i didnt buy another set to match these, i have some advantage racing wheels already i will switch all the tires too these as they are already about to come off the wheels lol
pipeous
5th Scale Guy
pipeous's Avatar
07.21.2008, 12:30 PM
cheap premounted tires and good rims at twister tire usa... shameless plug ya but I am really impressed with these tires. I stripped out my j concepts front on my b44. sucked because the tires had barely any use on them.
I am using the super soft compound. the sticky is designed for hard pack. I had softs and super softs in both sticky and adherence and just run the ss. I don't see any wear on these tires. hard to beat the priceand they haven't needed touch up gluing. they even drill the hole in the outside of the rubber which many pre mounts don't.
