Minimum Battery Specs?
fastbaja5b
fastbaja5b's Avatar
Minimum Battery Specs? - 01.28.2009, 03:15 AM
What is the Minimum Battery spec I need for a 4s Brushless conversion using a Medusa 2200 60mm can battery?
At the moment I have Reedy 5000's 20C which seem fine, but I can get some 4600's 20C, or is that too low?
What should I be chasing?
crazyjr
crazyjr's Avatar
01.28.2009, 03:22 AM
Really need the whole setup to really know, but so long as you got at least 90 amp continous you should be good. I have run 3700 mah 20c LIPO's on my MT with no problems, I have a G2R with neu 1515/2.5d w/quark 125, It has been run on 4,5 and 6s setups with those batteries
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
01.28.2009, 03:36 AM
i used to run my 8ight on a v2 2200-60mm medusa on 4s 5000 zippy's rated 20-30C and neuenergy lipos 4s 5000mah rated at 20C....the same motor and setup worked fine in my e-maxx as well...
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
