Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
RCM motor heat sinks
ffactory666
RCM motor heat sinks - 08.09.2008, 05:55 PM
Mike i am about to put another order in with you but have a question on you motor heatsinks.
I'll be putting them on both my Medusa 36-60 motors . Your S size heat sinks are showing that they work up to L size so they will fit the 60mm Medusa , is this correct or should i order the L size.
Also when will you have more stock of the CC Sidewinder .
Being in Australia i want to order everything together since postage is so high.
Cheers
bdebde
That's All Folks!
bdebde's Avatar
08.09.2008, 08:18 PM
The S size will work, but wont come to the end of the motor (51mm I think). To use the clamp part you would just need longer screws. The L size would work full length but may not clamp (61mm I think). I don't know if you need the clamp part for the Medusas.
08.09.2008, 09:41 PM
No real need to use the clamp feature, as the front enbell is integral to the can. The rear plate is pressed on, so the clamp may help that. I use std clip on heatsinks for my medusas...
ffactory666
08.10.2008, 12:58 AM
Thanks linc , not even thinking that the Medusa is 36mm like standard brushed motors
Have a couple of normal heatsinks lying around .
08.10.2008, 01:03 AM
If you have issues with the rear endbell coming off then the clamp may be a good idea. I will continue to run the std clip on heatsinks... You are welcome BTW!
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
08.10.2008, 01:30 AM
If the L size heatsink is only 1mm longer than the motor I'd go with that and just use some type of spacer if you need to clamp it. I like that idea more than using the S size heatsink with longer screws for the clamp. It has more surface area to dissipate heat anyways.
