which of the mamba max setup options effect top speed and which affect torque/acceleration? i want to set it up for top speed but dont want to strain the battery to much in acceleration could somebody please help me with the best options for this requirment
For softer acceleration, the punch control should be set lower. Generally, your gearing will determine top speed. You can try to set the timing higher, but that usually does not affect the top speed much, and can cause addl heat, so be careful and make sure you have a temp gun handy during testing,
