NEU motor question
CRTIM
NEU motor question - 09.07.2008, 03:42 PM
are you guys grinding a flat on your NEU motor shafts for the pinions or is locktite doing ok holding the pinions on ?? thanks for the help
bdebde
That's All Folks!
bdebde's Avatar
09.07.2008, 04:32 PM
Most will put a flat spot.
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
09.08.2008, 02:03 AM
The new Neu motors come with a little flat spot but doesn't go along the whole shaft. Stick the motor in a bag and poke a hole through it with the shaft (this will keep any debris getting in the motor) and then use a dremel or file to make a flat spot
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
CRTIM
09.08.2008, 01:37 PM
ok ...thanks guys for the help and tips ...appreciate it
