mamba max 1.2 and no reverse
auto2
mamba max 1.2 and no reverse - 11.05.2008, 09:47 PM
i updaated firmware on my mamba max from 1.7 to 1.20 and i lost reverse.
i have it set for reverse with the 2 sec delay. the light on mm lights up when i hit rev but thats it.
everything else seems much better. smoother less coging,
i rebound the spektrum and reset the raadio. 3pk
if i switch setting to fwd brake rev then i have rev. just no rev with the delay
DickyT
11.05.2008, 10:28 PM
did you reprogram the esc with the radio zeroed out? not a bad idea after changing firmware versions,
auto2
11.05.2008, 11:18 PM
yes did that
auto2
11.06.2008, 08:45 PM
no ideas from anybody?
auto2
11.08.2008, 10:57 AM
help?
auto2
11.08.2008, 04:20 PM
so if i go back to 1.17 firmware i get reverse back. also throttle is not aas smooth as the 1.2 firmware and it will cog if i spin the inferno gt out and hit forward while it is rolling backwards. with the 1.2 firmware it didnt cog doing same thing.
11.09.2008, 03:53 PM
Did you check on the castle link menu that reverse hadnt been disabled or the reverse throttle speed wasnt altered?
auto2
11.09.2008, 05:37 PM
when i go back to 1.17 firmware reverse works without changing anything else
