Maxamps have got another Hard Case Battery. Hopefully more will be coming out.
MaxAmps.com presents the ultimate hard case racing pack. As you racers know, the most important factor for your batteries is voltage under load. This pack boasts a 30C constant rating for all your amp hungry racing setups. It will maintain higher voltage under load than any other lipo battery pack on the market. Plus, you'll have no problem getting plenty of runtime with 6500mah of capacity.
30C Constant Discharge (195amps)
Hard Outer Case
139mm x 47mm x 27mm
7.4 Volts
6500mah Capacity
12.7 ounces
