Metric and Imperial Screw Sizes
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
Question Metric and Imperial Screw Sizes - 11.14.2008, 12:19 AM
How different are they?
I got told by one person that the screw I am after is M2.5 (metric) and another guy said 0-80 (imperial)
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
skellyo
skellyo's Avatar
11.14.2008, 12:30 AM
I've never heard of a 0.80 screw. Imperial sizes are usually termed as #2, 4, 6, 8, etc. What's the screw for anyhow?
bdebde
That's All Folks!
bdebde's Avatar
11.14.2008, 01:08 AM
The thread pitch is going to be a bit off even if the diameter is close, but as skellyo said, imperial sizes are numbers below 1/4". If screwing into plastic, it won't much matter, but aluminum/steel pieces may get the threads chewed out. If we knew what is what for, we could probably help you out.
DRIFT_BUGGY
11.14.2008, 01:52 AM
It is actually the small 4 screws holding the end on of the Neu Motors. I took the screw into a fasterner shop and they said 2.5 x 3 but couldn't get any screws that small. I asked Steve Neu how big the screws were and he said 0-80 (sorry I typed 0.80 in 1st post) They do exist - http://www.microfasteners.com.au/fas...ketScrews.html
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
bdebde
That's All Folks!
bdebde's Avatar
11.14.2008, 01:57 AM
Yep, that is imperial size 0, 80 threads per inch. That is a small screw
DRIFT_BUGGY
11.14.2008, 02:20 AM
lol, yes very small but cost more than larger screws
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
DRIFT_BUGGY
11.14.2008, 04:54 AM
I just realised that the screws that hold the shock pinion on the shaft is 2-56 x 1/4" and the screw looked about that size so I thought I would try it on the motor and it fit but you could wobble the screw a tiny bit in the hole. But isn't 2-56 bigger than 0-80?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
