Will disconnecting the red wire also disable the fan on the MMM?
pasan
I <3 RC
pasan's Avatar
Will disconnecting the red wire also disable the fan on the MMM? - 01.18.2009, 08:41 AM
I've got a 5A BEC that I'd like to use in my E-Revo to power a 20KG servo, but would disconnecting the red wire also mean the MMM's fan is disabled too? Thanks.
E-Revo - Mega ACn 22/45/1E MMM 6S
E-Maxx - Feigao 7XL MM 4S
AX10 RTR - Stock :D
Micro-T - Losi LiPo upgrade
Mini LST2 - Discarded. Useless POS.
1/8 Scale Baja Bug - Medusa 36-50-3300 eZrun 60A 3S
George16
Supermaxx
George16's Avatar
01.18.2009, 08:42 AM
No it does not disable the fan.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
pasan
I <3 RC
pasan's Avatar
01.18.2009, 09:10 AM
Great, thanks!
AX10 RTR - Stock :D
brushlessboy16
brushlessboy16's Avatar
01.18.2009, 09:59 AM
The mmm bec should power that servo fine tho.
pasan
I <3 RC
pasan's Avatar
01.18.2009, 10:23 AM
It should? I was told that the MMM BEC puts out something like 5.5V, and I need 6V for it to work well.
AX10 RTR - Stock :D
brushlessboy16
01.18.2009, 11:05 AM
iirc v3 puts out 6v.
pasan
I <3 RC
pasan's Avatar
01.18.2009, 12:15 PM
I've got a V2.
AX10 RTR - Stock :D
padrino
hmmm...
01.18.2009, 03:02 PM
Originally Posted by pasan View Post
I've got a V2.
Others will know better then I do but I think it may be worth exchanging the V2 for a V3. I do not know if CC did it only on failures but even if you have had good luck it may put you in a better position since teh V3 is more reliable, and as said above provides 6V.
azjc
01.18.2009, 03:17 PM
I think that when you disconnect the red wire with the MMM the onboard BEC will continue to work...not like the MM
