The 30150 is a premium controller that has many programmable features allowing many tuning options vs. the warrior. I read your other post regarding warrior trouble and would really like to try to figure out what the cause is. It simply is not a normal issue and must be being caused by something.
Based on your description of the warrior, any controller will have less cogging. :) The micro series should run smoother. It also can be programmed to fine tune the drive qualities (timing, startup smoothness, etc.).
Originally posted by RC-Monster Mike Based on your description of the warrior, any controller will have less cogging. :) The micro series should run smoother. It also can be programmed to fine tune the drive qualities (timing, startup smoothness, etc.).
cool, I'll prolly need to order that computer link and software to get at this. I'll wait and see how things are after it's all installed...
