What's that, 2650Kv's in the building?
Thomas Porfert
Thomas Porfert's Avatar
Post What's that, 2650Kv's in the building? - 01.09.2009, 07:03 PM
Nope, you're not dreaming, you heard right, a massive pallet of the Castle Neu 2650Kv (based on the Neu 1512 series) has finally arrived!
This first batch will only be packaged with combos, as we don't have quite enough to fulfill all of our current backorders.
But for those of you who have been patiently waiting for the 2650Kv combo, the wait will soon be over! We will be doing some spot testing to verify they're up to spec, and then they'll start rolling out. So get your buggies ready, your LiPo's charged and have some spare parts handy because they'll be up and running shortly.
Remember these are shorter than the 2200Kv (based on the Neu 1515), so they're intended for the 1/8th buggies and not the monster trucks.
Thomas Porfert
Castle Tech Support
phatmonk
RC carbon junkie
phatmonk's Avatar
01.09.2009, 07:16 PM
Thats too bad its not up to what the real Neu 1515s provide.I have a Tekno Neu 1515/1.5D/F in my truggy its 2700 kv like the CC Neu.Its more than enough power on 4s.
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
entjoles
01.09.2009, 08:22 PM
thanks for the update
himalaya
himalaya's Avatar
01.10.2009, 12:41 PM
So when will Castle's 1800KV version be ready ? That one is what I am dreaming of, though I already have the 2200KV combo.
....What a Blue Sky....
Sammus
Sammus's Avatar
01.11.2009, 03:05 AM
why is it too bad if yours is more than enough? this will likely be more than enough too, but smaller and more suited for car use.
YogyBrushless
01.12.2009, 06:13 AM
daarn i need to spend more money now !
__________________________________
Must Find Cash For RC
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
01.12.2009, 09:18 AM
Hm, thought it was going to be 1500Kv?
YogyBrushless
01.13.2009, 03:23 AM
this motor can handle a 5S right ? i`m asking because i`m getting this for my buggy and i thought i`ll use a 4S for racing and 5S for crazy bashing. it is ok right ?
Yousef
SeanZ0r
01.13.2009, 05:21 AM
Can I beta test it please?
heres a good home
AE Factory Team TC4 4c2p 6000 & MM 5700
Brushless Traxxas Jato MM 5700
SH Z-Car MMM2200/5s4000mah Turnigy Packs
jayjay283
jayjay283's Avatar
01.13.2009, 05:40 AM
Yousef
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 15
Total Voltage: 18.5
Motor KV: 2650
Tire Diameter (inches): 4.5
Tire Ballooning (inches): .5
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.4 : 1
Total Ratio: 11.24615 : 1
Tire Circumference (inches): 17.28 inches (438.88 mm)
Total Motor Speed: 49025 RPM
Vehicle Speed: 71.33 mph (114.58 km/h)
Effective KV Value: 2650
KT constant: 0.51 oz-in/A
I consider that conservative #s 71mph, call up JZ, way too fast
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
01.13.2009, 04:52 PM
Lets forget about the calculations for now. How do you know a 15 tooth is the right pinion. It could be a 12 tooth and calculated speed would only be about 55 mph. I think Edumkated radared his 1512 1.5D on 4s on 5s and he had speeds of 60 and 70 mph respectively. The Castle-Neu 2650 on 5s has about the same rpm as the 1.5D on 4s.
I plan to run the 2650 on both 4s and 5s for bashing. If you have to use this motor for racing, a high capacity 3s pack would be more suited. If only Castle came out with a version of the 1512 1.5Y, that would be great for racing on 4s-5s.
Area 52 Ranch Raceway
T.R.C.R.
01.13.2009, 04:55 PM
I've run the Castle 2650kv on 5s with no issues in my buggy and geared 20/51 on the GTP2 - Ran fine.
The long jump at the RCM bash was won with a CC 2650 on 5s :)
01.13.2009, 04:56 PM
Oh PS it will take 6S :) at just under 60k rpm
YogyBrushless
01.13.2009, 05:12 PM
thanks guys i`ll be running 8ight stock gearing so calculations say it 40+ on 4s and 50+ on 5s, i can live with that ;D
Yousef
hemiblas
hemiblas's Avatar
01.14.2009, 01:03 AM
Sounds great Thomas, but I'm still saving up for the 2200 combo.
