If you put UE Knucklehead shock towers on FLM hybrid bulks did you dremel the tower or the bulk? I really hate to dremel the towers but the tower hits right on the top hex. Anybody replace this hex with a screw? Do you think that would work?
a screw would work. I ground my towers, but they weren't ue towers. I'd switch to a screw and grind as little as possible, but a little grinding is unevitable.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
