Put this up again just to let you guys know I dropped the price even lower than the already dirt cheap price. I am in desperate need for quick cash so I need it gone asap. It is a 1/5 FS-Racing monster truck "exact clone of the MCD MT". Everything thats made for the MCD MT will fit it. Comes with a mounted Kollmorgen 400 18pole inrunner motor for gutwrenching power and good speeds. Im including #25 chain and an 11t and 13t #25 sprokets with 8mm bores for the center diff. Also including a 15t #25 sproket with a 12mm bore for the motor. Calculated the truck to run at around 35mph-40mph with the gearing, voltage input and kv and should have around . Needs radio equip, esc and batts. Everything else is included.
