clutch or pinion
brian2njoy
clutch or pinion - 03.30.2009, 09:49 AM
I have the mmm conversion but the 5 mm pinion that came with it does not line up with the spur gear its like the spur gear teeth are bigger than the pinion teeth nay help or just run a clutch thanks
03.30.2009, 09:53 AM
The MMM comes with an 18T 32p pinion - you need a mod1 pinion.
Check mikes store http://rc-monster.com/proddetail.php?prod=5mmmod1pinion
brian2njoy
03.30.2009, 09:54 AM
thanks
03.30.2009, 09:56 AM
No problem... Use this tool to work out your pinion size - Gear for 40PMH http://scriptasylum.com/rc_speed/
