Go Back   RC-Monster Forums > Support Forums > Slipperential discussion
Slip diff need shim help!
superek4
superek4's Avatar
Slip diff need shim help! - 05.07.2009, 03:38 AM
Mike need ur help, i have built & installed the diff but the gap is 5mm wide, may i know how can i shim it? i have a pix pls look thxs!
Name:	Slip diff3.JPG
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
Dafni
Dafni's Avatar
05.07.2009, 05:41 AM
I'd get two 16mm x 2.5mm O-rings and insert one on either side.
Or get some 16mm x 15mm x 0.5mm shims...
Or turn some 16mm x 15mm x 2.5mm spacers on a lathe...
superek4
superek4's Avatar
05.07.2009, 06:07 AM
won't d shim damage the diff bearing holder or bearings?Where can I get these shims? Is moving d center mount easiler? Just drill 2 holes nearer to d diff?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
brushlessboy16
brushlessboy16's Avatar
05.07.2009, 07:39 AM
no shimms are the same outside diameter as the bearing and dont hurt anything.
http://www.amainhobbies.com/product_...oducts_id/4260
If you go with shims your going to need a good bit of them.
superek4
superek4's Avatar
05.07.2009, 09:34 AM
Do I did to shim both sides or just 1 side will do?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
brushlessboy16
05.07.2009, 09:37 AM
either. whatever tickles your fancy.
superek4
superek4's Avatar
05.07.2009, 09:39 AM
Sure I will try today thx guys:)
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.07.2009, 10:50 AM
I would shim both side an equal amount.
superek4
superek4's Avatar
05.07.2009, 12:06 PM
It needed 8 shim each side I wonder if d bearing sits enough in d mount?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
RC-Monster Mike
Site Owner
05.07.2009, 12:08 PM
It will be fine - now go drive it already! :)
superek4
superek4's Avatar
05.07.2009, 12:22 PM
yes sir! One last question d diff is still moving sideway slightly like 1mm izzit ok?
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
RC-Monster Mike
Site Owner
05.07.2009, 01:00 PM
1mm play is OK. .5mm is better. A little play is better than too tight. Have you run it yet!?
superek4
superek4's Avatar
05.07.2009, 01:07 PM
thx, I will run it in d morning now it's 1am in Singapore :) zzzzz. I will post here for the review I m sure I will happy:)
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
superek4
superek4's Avatar
05.07.2009, 10:25 PM
I tried the diff today very nice no more wheelie even on 6s. I was running on slightly damp ground abt med traction. I allow abit more slip, more slip means more sound right?
Do I need to threadlock d screw after I set d slip I want?
I m not sure izzit my gear ratio or I m using a 11T pinion, the speed is abit slower. I will test it again on 13t.
I also notice d motor gets hotter faster.
I was told to use 8x16 bearings sand off the outer sleeves n use it as a spacer as the shims will eat into d housing izzit true?
So far very happy a new tuning tool:)
My Sponsors
Hobbywing
ManiaRc
Acorn racing
UpgradeRc
Blackbeard RC
Team Hong Nor
Team RC Monster
MoosRacing
BocaBearings
SweepRacing
Tresrey USA
brushlessboy16
05.07.2009, 10:34 PM
Sounds like your slipper is too loose.
The shims will be fine in the housing.
Try tightening the slipper a bit until you get your acceleration and speed back
