Monster Mamba Cut off??
Chris Corbett
Monster Mamba Cut off?? - 04.15.2009, 05:54 PM
Hi all
Finally rang my ST for the first time today. Running 80mm 2000kv medusa motor with 5s 6000mah lipo (enerland).
Absolutely awsome, unbelievable. Started with 15t pinion (stock spur) and seemed to find a perfect combination of acceleration and top end. Forgot to take temp gun but motor 'felt' a bit too hot so may try 13 and 14t for comparison.
One thing has really worried me though and that is the lipo cut off setting. I set it to the highest 12v but the manual must be for mamba max as it says this option is essential for running on 3s and anything over 3s voids the warranty.
The power dropped after 12mins or so and at first I thought it must thermal shutdown due to heat (I expected a lot longer than 12mins!)
Got home to charge pack and charger said low voltage press + to resolve. Did that and then it charged putting 6510mah back in!!!
I am worried that 1. I have ruined the battery and 2, my cut off setting is wrong.
Any advice greatly appreciated
jhautz
jhautz's Avatar
04.15.2009, 06:07 PM
for 5s you want a custom setting of at least 15V. I personally prefer running a 16v setting to give it a little buffer. It keeps the battery healthier longer if you dont run it down all the way.
If it didnt puff and you were able to charge it back up the battery is probably OK. But fix that LVC setting before you run it again.
to make it...
or break it...
Silent...But Deadly
Mamba Monster cut off
Chris Corbett
Mamba Monster cut off - 04.15.2009, 06:18 PM
THanks for that. I assume the custom cut off is an option on the Castle Link? I have the usb and downloaded the software but for some reason it is not reading the esc so I programmed manually.
Do you need power to the esc and switched on to link it?
It did work once but not this time!!
brushlessboy16
brushlessboy16's Avatar
04.16.2009, 11:47 AM
try a different usb port
Jeremy1976
04.16.2009, 12:18 PM
You do not need the power on to get it to work. Just plug it in.
