might get but got questions
Shadow350Z
Shadow350Z's Avatar
might get but got questions - 07.27.2005, 01:51 PM
I might ask my dad for a G2 X-Brace Aluminum Chassis from Gorilla Maxx
will it extend the truck and make it a little longer??
I wanna keep my truck's stock wheelbase
will MIP Center CVD's for the E-maxx work with the g2 chassis??
if i get the g2 chassis
wut would be the best way to protect the underside from scratches??
I am also thinking of asking for the g3 susp kit
but i can only ask for one
likes about g2 chassis are My electronics wont be so clumped up like right now on my stock maxx chassis
dislike bout it is the batteries are exposed on the sides from dirt and rocks that are hitting the batts that are coming from the front tires
likes about the g3 race susp kit are that it has many option of shock setting and wanna set my maxx as low as possible and the lowered shock towers looks nice and i can lower my body
dislikes about the g3 race susp kit is its a lil bit too much? 279.99$$ and also if i get the g3 how am i gonna protect the underside from scratches ??
thnx
  Send a message via AIM to Shadow350Z
Shadow350Z
Shadow350Z's Avatar
07.27.2005, 06:49 PM
nobody want to help me dicide??
coolhandcountry
coolhandcountry's Avatar
07.27.2005, 07:09 PM
The g2 chassis will extend your truck but only about 1/4inch. The mip cvds work with the g2. As far as scratches go. The only way i know is don't drive it. lol Stay out the gravel helps.
Peace!
Country
Help support the
Rc-Monster
Buy here
MaxxFusion
MaxxFusion's Avatar
07.27.2005, 10:06 PM
I went with the RPM wear plates underneath to help protect a bit but you wont elimate scratches.
  Send a message via MSN to MaxxFusion
Shadow350Z
Shadow350Z's Avatar
07.27.2005, 10:44 PM
ive been thinking..
will a sheet of thin lexan work??
and wut to ask for my dad first??
the g2 chassis or the g3 susp?
rchippie
rchippie's Avatar
07.28.2005, 02:14 AM
Shadow
I use associated chassis protection tape for the bottom of my cf gmaxx. It is a very very durable & sticky teflon type tape. It cost about $10.00 a sheet 1 sheet is more than enough for your truck.
REAL MEN RUN BRUSHLESS
Shadow350Z
Shadow350Z's Avatar
07.28.2005, 02:52 AM
thnx rchippie
ok now i need siggestion on which to ask for???
g2 chassis or g3 susp?
Sneeck
RC-Monster Custom
Sneeck's Avatar
07.28.2005, 03:41 AM
If you actually get one of them for free go for the chassis. More important and better handling imo.
  Send a message via MSN to Sneeck
Shadow350Z
Shadow350Z's Avatar
07.28.2005, 03:49 AM
k go for chassis
buh how do i protect my batts from rocks??
rchippie
rchippie's Avatar
07.28.2005, 04:28 AM
Shadow i would get the chassis first. check my eairler repliy on how to protect the bottom of your chassis & batteries. You can also lower your body as far as possible to protact them on the sides. You can also extend the sides of the body if needed. Ask mike for the pics of my gmaxx it has the sides of the body extended to protect the batteries.
If you are running BL i would get the extended chassis.
Shadow350Z
Shadow350Z's Avatar
07.28.2005, 12:42 PM
thnx rchippie
ima ask for the chassis when my dad is in a good mood...
and thats rare
T2693
T2693's Avatar
07.28.2005, 03:36 PM
I have the G3 suspension and the G2 CF Ext Chassis.
Both are solid, extended chassis or not, and worth the money in my opinion.
I too have the RPM skid wear plates for front and rear protection however the main chassis is exposed. No matter what you do it's going to get dirty/nicked up unless you leave it on the work bence like a museum artifact.....;)
  Send a message via Yahoo to T2693
Shadow350Z
Shadow350Z's Avatar
07.29.2005, 01:02 AM
I wanna get my g2 xbrace alrdy! but i have to wait for my dad
i ran my E-maxx 2day and it was Lock detecting sumthing but everything was fine no binding no nothing
check the wires nuthin again
check my spur and pinions... nuthin
i reporgrammed my HV and now it works
I want to make my batt side side by 7cells right now its shotgun 6cell with a 7thcell attached to the side...
if i rebuild my packs to 7cell side by side
wut stuff should i use??
i know i want to use deans ultra plugs
which jig should i use?
how bout wires?
which probars should i use??
which solder?
what is the best soldering iron?
i dunno anything else i need
if i missed anything please add
sorry for the many questions
but i dont wanna get the wrong/bad stuff cuz i dont have any money for mistakes
thnx:D
Sneeck
RC-Monster Custom
Sneeck's Avatar
07.29.2005, 04:06 AM
Ok here we go;
Battery Jig
Wire
Battery Bones
Solder
Soldering Iron
Deans
That's about it. I would recommand glueing the cell's together using a hot glue gun.
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
07.29.2005, 10:22 AM
Make sure you have some flux, thats the most important part of soldering.
While we're at tower here...
Flux
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
